Help needed starter motor will not disengage
apgodden
On the bench the starter works as it should.  In the car it keeps turning with the key removed.
The 12v is only on when the key is in the start position.
If I remove the main 12v direct to the battery the starter motor sops and when the wire is put back on it dose not turn the engine “normal until I try and start again then starter mot dose not disengage
The starter motor works on the bench perfectly.  If I take the solenoid wire off it still runs on.
also it’s a brand new starter motor that I have used before the engine rebuild?
I have just taken the engine out and removed the clutch and flywheel and reinstalled and it’s the same.
So that I understand correctly.
Starter was good before rebuild and nearly new.
In the car ignition switch to start and starter turns engine over.
Release ignition switch and starter keeps going.
Pull wire off starter solonoid and it keeps going? This is the part that is interesting.
For the solenoid to pull in or hold in it requires current to flow.
With the solonoid wire disconnected current should stop flowing.
The fact that you see 8V at the terminal makes me think that there is a connection in the solonoid to the high current motor contacts. 2 things come to mind either some swarf has got in or there is distortion within the solonoid (it is bent) causing a short
