Wednesday at 12:17 PM5 days 19 minutes ago, steven52 said:Hi everyone. I have a funny problem with my car with the weber 40 DCOE carburator. The engine doesn't start at all. Initially i thought problems with the fuel line and pump. Replaced all of that, good flow now with clean fuel. But not starting. Now comes the funny thing. If i put fuel in a pressurised spraycan and connect that to the carburator. The engine just runs perfect. But on the fuelline nothing.any thoughts? Cheers Steven
Thursday at 01:49 PM4 days I checked the float height and adjusted this according the specs from weber.
Thursday at 01:53 PM4 days I must say the petrol in the spraycan was brand new petrol. The petrol in the tank is super clean and not that old but gonna try with fresh petrol asswel.
Friday at 01:21 PM3 days New petrol today. Still not starting. Waiting for my fuel pressure regulator. See if that solves the issue.
Yesterday at 01:19 PM1 day The pipe that comes from the tank, either through a mechanical lift pump or electric pump to the Weber, are you getting fuel at that point, if you're not that the problem is before the Weber. If you are the fault is the Weber, it's either got a blocked pipe, blocked strainer (if fitted), blocked float valve, or a blocked jets. Logically it cannot be anything else if it runs with fuel down it's throat, if needs 4 things, compression, you've proved it, it runs, spark, you've proved it, it runs, air, you've proved it, it runs, so can only be the fuel delivery system at fault.
1 hour ago1 hr Hi Phaeton. Thank you for thinking with me. If i empty the carburator it fills up after a couple of cranks. So no blockage there. I checked the jets not blocked. I have compression sparks and the timing is set. All the cables on the correct spark plug.
