June 29, 20215 yr Hi we are currently building a superspec with the Ford 2.0 Duratec fitted which flywheel / clutch do you all use to match to the Robin hood supplied MT75 gearbox I currently have the dual mass flywheel still fitted which came with the engine. Many thanks for any suggestions.
June 29, 20215 yr Author I should add that the ford duratec has a adapter plate to mount the original robin hood MT75
June 30, 20215 yr Hi, I have the Duratec in my 2B which is mated to a type 9 gearbox. I used the solid flywheel from a Fiesta ST 150, re-drilled to take a Pinto clutch. I understand that the dual mass flywheel often gives trouble. Not sure if the solid flywheel, ST clutch would fit the MT75 gearbox though.
June 30, 20215 yr Author Thanks for your reply, were you able to use the original starter motor or the ST150 one?
