ford duratec
RH2BJS
Hi
we are currently building a superspec with the Ford 2.0 Duratec fitted
which flywheel / clutch do you all use to match to the Robin hood supplied MT75 gearbox
I currently have the dual mass flywheel still fitted which came with the engine.
Many thanks for any suggestions.
Hi, I have the Duratec in my 2B which is mated to a type 9 gearbox. I used the solid flywheel from a Fiesta ST 150, re-drilled to take a Pinto clutch. I understand that the dual mass flywheel often gives trouble. Not sure if the solid flywheel, ST clutch would fit the MT75 gearbox though.
