Seat Belt
peter
Need a little help?
I am building a Robin Hood 2b and am wandering how you fix a four point seat harness.
I seem to be ok with rear and side, but do not know how to fix mount nearest center, ie around drive shaft column.
I have a couple of 1/8th bars spanning the floor for seat fixings.
Thanks,
Peter.
Peter, you will need to provide the fixing by fixing / welding  to the cross bars and ideally welding to the tubes that form the top of the transmission tunnel. There has been many designs I am sure others will comment. I fitted the kit spares IVA plate to strengthen the floor so fixed to this and welded to the tubes. You will also need to have captive nuts on the inner and outer lower fixings
Steve D
