July 27, 20224 yr Hi I'm new to the forum and my robinhood I'm having trouble with my robinhood 2ltr efi dohc I thought the battery was weak as it hasn't been used much in the last year and it was struggling to start without the booster so replaced it had the starter motor reconditioned and still my engine don't want to starter I'm getting just clicking or nothing at all any ideas Thanks John
July 28, 20224 yr Possibly a dodgy solenoid although being part of the starter it should have been tested when the motor was reconditioned. My money would be on a loose lead to the starter or a poor engine earth
July 28, 20224 yr +1 for the above. The clicking is the gear coming out of the starter motor to engage with the flywheel but if you're not getting any cranking, that is either a dead solenoid or dodgy wiring/earth.
July 28, 20224 yr Author 1 hour ago, kevin the chicken said: Possibly a dodgy solenoid although being part of the starter it should have been tested when the motor was reconditioned. My money would be on a loose lead to the starter or a poor engine earth Thanks The solenoid was replaced same time as the recon and tested by auto generators ill be cleaning connections today and checking the earth aswell thanks
July 28, 20224 yr connect a jump lead from neg on battery direct to bolt on the starter motor and try if ok then you know you have a bad earth Edited July 28, 20224 yr by max
August 5, 20224 yr Author Update cars now running I had a bad new battery kicking out less than five volts on start up . On bright side I have a freshly reconditioned starter motor and selanoid all my earth wires and other connections are nice and clean and now been to my local monthly meet up ... only 2 other members there hopefully there will e a few more attending next month
