Aero Screen on a 3a
LeicJim3a
Looking at removing windscreen and fitting an aero screen preferably double bubble type. Just because in 6ft 2 and looking straight at top of the screen ! can anybody recommend one that will fit ? I've seen plenty for westies etc... but not sure how close to fitting these would be ? Even better if you have one at the back of the garage you want some dosh for ????
Sorry can't help with the screen but I'm just thinking that I had a similar issue with my 2B and realised (eventually) that my seat was too high and the top of my head was above the roll bar.  If you rest a length of wood between the roll bar and the top of the windscreen you'll be able to tell if your head is above it.  I managed to get my seat fitted quite a bit lower and that then got my head below the roll bar and I was then looking through the glass rather than the frame.  I did eventually fit a larger screen as well.
Hope this helps,  Steve
