Zetec supercharger
Hi new member here although i was a member s few years ago in hoping i can get sone advice I recently bought myself another robin hood its fitted with a 2 litre zetec which has a supercharger fitted
im having a lot of trouble tuning it
its fitted with a microsquirt ecu is it a simple enoigh job to remove the supercharger and remap the microsquirt ? And use it as an efi ?
If it was me I would have kicked that cup of tea over within seconds of putting it down 🤪
There is a good chance that the engine had it's compression reduced in some way - head spacer, thicker head gasket or similar when the supercharger was fitted.  If so you would really need to put it back to standard if you removed the supercharger.
I would imagine it would be easy to re-map the ecu but I don't know enough to help there - hopefully someone else can give you some info. on that.
It might be worth explaining exactly what problems you're having with it and seeing if anybody knows of any easy fixes .............  if there ever are such things.
How are you trying to tune it,
To tune my zetec supercharged silvertop it has to go to rolling road, unless you are extremely skilled and then you could maybe do it on the road but very dangerous,
What issues are you having ?
Idles ok but touching the throttle it splutters and stalls its ok upwards of 2500 rpm but awful up until 2500
its been tuned but not on a rolling road my local one doesnt do microsquirt
It might be worth asking this question on the Locostbuilders site, I expect there will be more experience of this setup on there.
