August 30, 20251 yr Had to replace the brake MC it was rusted up solid the kit's not been used for a few years, not been able to purchase the exact same MC as they are no longer made, but assured the one I have bought is a suitable replacement. I bench bled the MC, with a couple of bleed nipples into the MC with it on the bench I was not able to push the cylinder in. Fitted it to the car & still with the bleeds in I'm not able to push the pedal it's solid, connected the back brakes & could not bleed them, pedal would go straight to the floor. I'm now at the point where I have disconnected the T where it splits to the rear brakes & put 2 bleed nipples in there, in my mind all I have now done is move the bleed from being connected to the MC & fitted it to the end of the first length of braided hose, I should still get a solid pedal but I'm not the pedal is going to the floor. It's got to be air in the system hasn't it, but I can't get it out. I've tried an ezbleed but even with only 4psi the MC leaks around the top, I've tried to vacuum bleed from the far end with still no joy Ant pearls of wisdom?
August 30, 20251 yr My reaction is braided hose aged and ballooning. Can you get someone to step on the brakes when you observe the hose? Alternately try blanking the rear outlet and bleeding the fronts one at a time if this works it has to be in the rear brake line so replace the lot as brake failure can be very expensive.
August 30, 20251 yr Probably silly question but are you sure the new new cylinder piston is fully returning when the pedal is released?
August 31, 20251 yr Author On 8/30/2025 at 7:10 PM, IanS said: My reaction is braided hose aged and ballooning. Can you get someone to step on the brakes when you observe the hose? Alternately try blanking the rear outlet and bleeding the fronts one at a time if this works it has to be in the rear brake line so replace the lot as brake failure can be very expensive. I've now disconnected the rears at the at the tee as they split & still cannot get a solid pedal, I'm leaning towards a faulty MC On 8/30/2025 at 7:52 PM, Peter Bell said: Probably silly question but are you sure the new new cylinder piston is fully returning when the pedal is released? There are no silly questions, I've ordered another MC from another supplier supposedly another manufacturer, as I'm not convinced the original new one is drawing fluid from the reservoir which could indicate the piston is not returning as you suggest.
September 1, 20251 yr Interesting, you don't say much about the MC, what original car is it from ?, is a servo involved? some MCs have three outlets, two for fronts and a rear, is a pressure adjuster fitted in the rear line ?, you know the one that favors the front on de-acceleration. Beware using a bleeder nipple, there are two sorts of unions possible and some kits end up with a mixture (mine does). The "metric" ones have a bubble flare on the pipe and a concave shape in the female, the other type ("SAE" I think) have a double flare on the pipe and a convex cone on the female. I think that the bleed nipples are only meant for the concave female, as found on the slave cylinder (rear) or calipers (front). The T piece that you have at the rear split, could be either, and I would worry if using a bleed nipple on the SAE type might damage it .... this has nothing to do with bleeding I know, just something to be aware of I think. As for the bleeding, I have found that the best way is to get a friend (or enemy) to operate the brake pedal, while I open and close the bleeder, you know, open the bleeder shout "push and hold" close the bleeder shout release etc.
September 1, 20251 yr Author 2 hours ago, Sparepart said: Interesting, you don't say much about the MC, what original car is it from ?, is a servo involved? some MCs have three outlets, two for fronts and a rear, is a pressure adjuster fitted in the rear line ?, you know the one that favors the front on de-acceleration. Beware using a bleeder nipple, there are two sorts of unions possible and some kits end up with a mixture (mine does). The "metric" ones have a bubble flare on the pipe and a concave shape in the female, the other type ("SAE" I think) have a double flare on the pipe and a convex cone on the female. I think that the bleed nipples are only meant for the concave female, as found on the slave cylinder (rear) or calipers (front). The T piece that you have at the rear split, could be either, and I would worry if using a bleed nipple on the SAE type might damage it .... this has nothing to do with bleeding I know, just something to be aware of I think. As for the bleeding, I have found that the best way is to get a friend (or enemy) to operate the brake pedal, while I open and close the bleeder, you know, open the bleeder shout "push and hold" close the bleeder shout release etc. The original MC comes from a servo assisted circa 1989 Skoda 136, original part number 443611020008 this is the replacement I have just bought https://www.ebay.co.uk/itm/336142079829 which looks identical or appears so from the one I had previously bought, but both differ from the original. All the lines are stainless braided on banjo bolts & fitting, the only other thing is weird setup that I have never seen before. There are 4 pot calipers on the front which have individual plumbing for the top 2 pistons & the bottom 2, the the rears are drums with single cylinders with 2 pistons each. Now the weird part is that the rears & the bottom 2 pistons on each front caliper are plumbed into the outlet nearest to the servo & the top 2 pistons on each front are plumbed into the outlet furthest away from the servo, this is as per Skoda's original setup. But that should not make any difference if none of the calipers or cylinders are connected & I still can't get a hard pedal.
September 1, 20251 yr I had a 1973 range rover discs all round 4 pot front and 2 pot rear. I circuit to the top fronts only and the other to bottom fronts and rears. I understand this was normal at the time. I also had an 86 mini metro plumbed like you describe. In case of a leak you always had front brakes.
September 3, 20251 yr Thanks for the detailed description of your setup, I read it with great interest. It's so unlike what I have encountered before. I immediately googled "banjo brake fittings" and other similar phrases and questions for the AI, to discover that what I thought was a system only used on motorbikes and quad bikes etc is used all over the place. I can see the attraction of not needing to get involved with the pipe flaring tools and only needing copper washers and flat surfaces for a pressure seal. In the photo that you attached it looks like you have a double banjo connector at the front MC position ? i.e. Two pipes connecting to a single stem bolt.? On your installation are all the pipes flexible braided hose ?, or are there some solid tubing sections?. Also I see the MC you use, this is also of interest, because I am in the process of trying to use a MC from a Ford KA, instead of the one from a Ford Sierra MK1 which are hard/expensive to obtain, the Skoda one pictured looks another option especially as it appears to be already set up to use a remote reservoir ?.
September 3, 20251 yr Author 2 hours ago, Sparepart said: Thanks for the detailed description of your setup, I read it with great interest. It's so unlike what I have encountered before. I immediately googled "banjo brake fittings" and other similar phrases and questions for the AI, to discover that what I thought was a system only used on motorbikes and quad bikes etc is used all over the place. I can see the attraction of not needing to get involved with the pipe flaring tools and only needing copper washers and flat surfaces for a pressure seal. In the photo that you attached it looks like you have a double banjo connector at the front MC position ? i.e. Two pipes connecting to a single stem bolt.? On your installation are all the pipes flexible braided hose ?, or are there some solid tubing sections?. Also I see the MC you use, this is also of interest, because I am in the process of trying to use a MC from a Ford KA, instead of the one from a Ford Sierra MK1 which are hard/expensive to obtain, the Skoda one pictured looks another option especially as it appears to be already set up to use a remote reservoir ?. All braided hoses, all the way from the MC to both front & rear brakes, the new MC arrived today but the weather is terrible here today so nothing is going to get done today
October 29Oct 29 Hi fellow suffererDid you manage to sort your problem?I had the same issue on my Robin Hood Ford 1.6 pinto and gosh did my wife get fed up with constantly helping to bleed them through. Finally though I isolated the problem to the rear brakes proportional valve being faulty - probably so rusty inside that you could not purge the air. I removed the valve adding a T piece with an upper bleed nipple. Also as with most problems its never just one item - the front ford callipers have a bleed point half way up the piston body - in old callipers the air gets trapped in the top section - I found by removing the calliper, rotate so that the bleed point is upper - gently tap with a hammer to unstick the air / bubbles and then bleed normally. lock off and refit the calliper - all good. I have have brakes that stop the car -- and a happy wife.
30 minutes ago30 min A common problem is an airlock in the brake line going to the rear brakes if the brake line is fitted at the top of the tunnel.the easiest way to fix it is to jack up the rear of the car to a scary angle, so the rear brake cylinder is higher than the brake line, then bleed it.Ive helped fix this on several new installations.
