Please help 2.0 pinto won’t start
Sounds to me like you're 180 degrees out on he dizzy - firing at the right time but on the exhaust stroke, not on the compression stroke.
If only he had checked that 10 days ago https://www.rhocar.org/?app=core&module=system&controller=content&do=find&content_class=forums_Topic&content_id=52286&content_commentid=420004
Cam timing needed to be advanced one notch on cam and distributor needed to be advanced but I got it running great
the electric fuel pump went out same day but it was purrring like a kitten
thank all of y’all so much for the advice it was very helpful and appreciated
Good to hear you got to the bottom of it, fuel pumps are one of those tings that just seem to happen, take it off & bench test it before consigning it to the bin, it could be a wiring issue if it's been sat for a while, do you have a pre fuel filter fitted, again if been sat a while it may have pulled some crap out of the tank which has blocked the pump.
Its weird the first it had went out same day like i said and i bought a edelbrock one from the local parts store and it will un prime its self while driving so i just bought a mechanical one it'll be here in 2 days luckily it was easy to get
I’m not going to throw it away though my fuel tank vent is in a place to where it won’t take a lot of fuel at once so I carry a can and siphon hose around to transfer the fuel faster I’m just going to use the electric fuel pump to make things faster
