  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Super spec alternator
Hi All
We're progressing on with our superspec repairs now that we have an engine that starts..😃.
There's so many things on the car that have been messed with and not put back together right, even bolts missing from brake calipers, manifold bolts etc.
Out next step is to get the plumbing sorted so we can run the engine to temperature. There's no belt on the water pump and alternator but I can't see how this is going to work as the alternator pulley is around 2" backwards from the line the belt should run on. Does anyone have any photos of that area on their cars they could post for me to get some insights into what's wrong with ours?
I'll get a pic of ours later too.
Cheers,
Jon
This is the alternator on my Superspec. The belt lines up nicely on all the pulleys, so perhaps your alternator is not mounted correctly?
Also, there were different arrangements of alternator, power steering pump and water pump depending on whether the original Rover engine had an air con pump. Mine is a non-aircon.
Thank Andy, yes it’s definitely mounted incorrectly. Off to the garage shortly to try to get to the bottom of it.
My power steering pump is above the alternator.. . perhaps they're on the brackets in the wrong positions? I really can't see how the alternator could be mounted any further forward on the lower mounts where it is now and it doesn't seem to line up that great with them either
Another pic
I'm really not sure that the alternator, which came with the car, loosely hanging on one bolt is the correct one for my engine... The part number of it isn't easily read but starts 5402.....
The more I look at the car the more I see that's been messed with....
Can anyone advise which is the correct alternator for the T16 engine with steering pump?
Thanks, Jon
I don't think there was an 'official' alternator for the T16, any one that provided sufficient power would be OK. It looks like your engine, like mine, was designed decided for a Rover fitted with aircon. If you send us your engine Number we can give you a complete history for it. It looks to me that for some reason known only to RHE, on our engines they decided to mount the alternator on the aircon compressor mount rather than in the usual place. When it comes to mounting it you have to be resourceful 😄 You can see that my builder didn't worry about how many washers he used. What you can't see is that this is the back of the alternator and the bolt goes another 6" or so to the mount on the front of the alternator. It looks like a bodge but has been fine now for 18 years,
image.png.
And here is the front view
Yes, when RH sourced the Rover engines some were for aircon cars. As Al says, we can tell you from the engine number, which is stamped under the exhaust ports. RH didn’t use the aircon pump and moved the alternator to make the engine more compact.
According to my Haynes manual for the 820 the T16 used this alternator - Lucas/Magneti-Marelli A127, A133 or A1271 outputting at least 85 amps.
Andy
Thanks for those pictures Alan, i see your build has the bottom mounting hole enlarged so that it will fit to the incorrectly spaced mounts behind too. We will, in true RHE ethos be resourceful!
