October 29Oct 29 Hi could I get a age plate by points. Everything is from the doner citroen except the body work.
October 29Oct 29 Yes, probably but it's not that simple. Have you just put a new body on on existing, unmodified 2CV floorpan?
October 30Oct 30 Do you have the VIN & V5C of the original donor car, is the engine the one that was fitted into the original car.If the replacement chassis is identical to the original chassis & was fitted to the donor before it was stripped (nudge nudge wink wink), you have the V5C & the VIN is on the replacement chassis then you will get an age related plate, you could potentially bypass the IVA as all it is is a rebodied vehicle, you would have to check with the DVLA on that one though, it's not a road I have travelled. But as I understand it if the body can be unbolted from the chassis, no cutting of the chassis is involved then the vehicle will keep it's original identity & you can get the name changed, that's how all the VW buggies are even though the short ones should be IVA'd as the chassis is cut.However if the replacement chassis was supplied after the donor was stripped then it's a full IVA & potentially ending up on a Q plate.There is also a dedicated Pembleton Owners club & as much as I don't want to deter you posting on this site you may get more specific answers on their site, but either way come back & advise how you are getting on. Edited October 31Oct 31 by phaeton spilling mustacks
