Mot
Guest Billy-no-m8s
There's a plastic park switch fitted to the lucas motors and they are famous for clogging up and corroding. If you open it up you'll see the problem, but poutting it backj together again isn't too easy. Best solution is to replace the park switch. There's one for £7.50 on this page:
http://www.s-v-c.co.uk/SVCWIPERS.HTM
Ant
This is a quote:
3. The wiper blade or blades
shall return automatically to
a position of rest which shall
be at or beyond the outer
edge of the area swept by
the wiper and shall be
capable of being displaced
from this position on the
windscreen to allow for
windscreen cleaning.
from this document
Don't know how current - there are a lot of things in the vehicle regulations eg postioning of lights, that are not checked at MOT - but which presumably would be checked for SVA. When I built mine I got all the info from the library but that was before the interweb.
Is this another one of those issues to do with the date of the donor or the date of registration. My donor car would have self park but would not have the park setting that drops the blades a little lower.
  • 1 month later...
