Hazard Lights
Guest docter fox
Guest docter fox
look in the haynes manual for the pic of the clip to see which wire to snip?
you could of course just realise you don't have rear wipers and stop pressing the switch :rolleyes:
  • Replies 35
Can you remove the column switches and test. Sounds as if the supply to the switches is fused and the output is distributed direct to the front wipers, washers, rears etc. Determine the supply by testing each plug socket in turn with the fuse in and out. Then test the switch and see which output blade only comes live when you operate rear wipers and/or washers.. Then disconnect this/these wires from the output plug.
Guest docter fox
It arrived this morning and after about 10 minutes of attacking the packaging :lol: I fitted it and it worked fine :) Thanks for the help, the indicator stalk makes a better clicky sound now aswell :D
