Hazard Lights
Guest docter fox
  • Replies 35
So did mine... they came from the Mk5 Escort. So did some of the dash pods... (If you have one without a rev counter then that's where it came from...)
Guest TerryBarry
Mine has the horn push on the end
There came a point where Uncle Henry put the horn push in the steering wheel boss and the column switches changed.
Also at some similar time ( ~1988-9) the Escort changed to very short stubby column levers for indicators and wipers
Guest Petemate
Spot on Terry. I didn't like the idea of the centre horn push on the Mountney wheel, so I got an indicator/hazard switch assembly from an early Sierra in the scrappy, with the early steering wheel without the horn push. Works a treat, and as the Metro is similarly equipped, I'll have no trouble going between the two...
Pete
does anyone know what each of the terminals are for on the rear of what i presume is an escort one peice column switch? If i move my column switch to the rear window washer position, it blows a fuse, and i haven't a clue what could be connected to it! (not that this is a major problem, but i don';t want to blow a fuse everytime i knock the switch!).
Andy
Leave the fuse out as there should not be anything connected to it I would think that if the donor loom was used then a wire that should have been removed hasn’t been and has got itself shorted to earth. Could be a right pig to find even if you built the car in the first place.
no fuse means no front wipers, as i found out in the pissing rain when i first discovered this fault, so that's not an option!
I think it uses the donor loom, but surely there must be something connected to the back on the stalk, which i could remove, if all it is doing is causing the fuse to blow.
