With the basic frame assembled, we could measure the overall sizes which will give a starting point for planning out the awning. The overall height at the awning rail is 1650mm which slopes down to 1600mm at the side frame. It’s only 50mm fall on the roof but hopefully this will be enough to shed any rain. If we make the fall bigger, it will reduce the internal height too much.
The floor area is 1250mm x 2450mm, so pretty well doubles the footprint of the caravan body.
We did a test fit of the current awning roof part to the awning rail. It didn’t prove much other than it fits the rail and it’s far too big. The grey material that’s visible is the existing roof, more than long enough to go the entire length of the awning rail. To make it a bit more manageable, we cut it down in the length and width but made sure we left a generous allowance of material just in case we needed it.
This is one of the existing end panels laid out on the floor. It zips in to the main roof part all around the outside with a single zip.
And here’s one of the two front panels. To give an idea of the size of the awning we’re making, it’s front panel will be a bit smaller than this.
The plan is to use what we can from the original awning. We will be using the zips, windows and some of the red fabric, together with the grey vinyl skirt at the bottom that tucks inside the awning and goes under the groundsheet.
We carefully unpicked the stitching from the zips. They will be too long but look like they can be shortened fairly easily.
When we reuse the white fabric, we don’t want to use areas that have previously been sewn through as this will leave holes where water may get in. Instead we will cut out the panels close to the existing stitching to keep them as big as possible.
With the white fabric removed, we decided to give it a run through the washing machine. Although the awning was very clean, there were a few marks on the white and it made sense to try and remove them now, rather than later when the whole thing was sewn together. Also, while the fabric was still damp from washing, we gave it a quick iron to remove the bigger creases which will make it easier to work with later.
We will use new blue fabric as well on the awning, but the old red material won’t be wasted. We will carefully cut it out to usable pieces and keep it for possible use on other projects.
