Well done on the steady commitment. Looks VG.
Couple of adjustment points to bear in mind on suspension. The 'floor pan' line should be slightly higher at the back than at the front. Your pic suggests it's currently slightly higher at the front.
Shocks should be at rest with two third of their piston shaft exposed as a starting point. i.e. if the shock has a piston shaft that allows three inches of movement, meaning shaft invisible when fully compressed, 3" visible when fully extended, then at rest you should see two inches of exposed shaft. This is to allow adequate shock extension and compression available so suspension movement is controlled, not on the bump stops. (Does require you to have the correct length shocks for the car.)
Corner weighting is a refinement for later but is more about getting the sum of the diagonals closer to equal than each side equal.
All done loaded ie one or two passenger weights in the seats half tank of gas and the car rolled on the level to settle the suspenders.
Although it is important that it looks nice it's more important that it works nice with these cars.
