Thanks all. I am luck enough that i dont have an holes pre drilled. This means i get a choice. Having done some mock up i think i will be copying Dan and go with the passenger side park.
It seems to sweep a bigger area of the drivers side and higher on the screen too. Having a blank canvass means i can fit the screen and then tweek the wipers to fit.
What could possibly go wrong!!
Make Robin hood
Model Superspec
Engine 2l rover T series
Gearbox MT75
What I like Gold Titanium Coating
What I would change Suspension and shame you can't tune the engine
Well Mark has saved me posting a photo so here goes.
Make: Robin Hood
Model: 2B
Engine: Rover 4.6
Gearbox: R380 with taller 5th gear
What you like the most: The noise
What you want to change: Anything I can to keep me busy at the moment.
That's quite weird - my holes are symmetrical from that CL (2015 GT chassis, holes pre-drilled) so I had a choice which way to park them. I tried them on passenger side but seemed a bit better on drivers side - not much in it.
if you want a sub 4 sec 0-60 time I suggest tou try a winch launch of a glider with an enthusastic winch driver.
2 sec is possible with 20 sec to 1000 feet up, even better is a cat launch from a carrier but harder to arrange.
