I knew someone would advise using the Mini/BMC type mechanism, it's just so obvious, the problem is with my attitude not to let the bone go, it's a case of "I've started so I'll finish syndrome" ISSIF. I have now extended the arm by 10mm and remounted the motor. The added sweep is not great but welcome. As Bob says I can see that if the slave arms are shortened then this gives a better "bang for the buck", also this has the advantage of choosing a different sweep for each wiper AND only one cut and weld on each arm AND the effect can be trialled by temporarily overlapping the cut arm to set the added sweep to exactly that needed. Thanks for the suggestion, I'll keep you posted.
