I think you need to consider the operating temperature of the fan switch.
For arguments sake, if your thermostat opens at 88C and your fan switch (fitted to the bottom hose) operates at 95C, would you want to wait until the coolant leaving the radiator reaches 95C before the fan cuts in? What would the temperature of the coolant leaving the engine be at this time? If the fan switch is located in the top hose the fan will cut in when the coolant leaving the engine reaches 95C. When the engine is at normal running temperature the fan would not always be on because the coolant has not reached the switch operating temperature.
