Leaderboard
Popular Content
Showing content with the highest reputation on 12/12/2021 in all areas
  1. My 2B has two M12 bolts through each side. 1 through the centre of the rubber bush (although I've now removed the bush and made it solid), and a second about 60mm further back, both going through the corner plate of the chassis. I'm not sure how this relates to a 3A but I reckon M12 bolts should hold things together OK.
    1 point
  2. If imperial was a possibity I would say 31/64th inch. (worked in aircraft industry where imperial bolts still used with increments of 1/64) 31/64 would be 3rd oversize repair bolt for 7/16 initial bolt. On most builds the rear subframe rubber donut was removed and a new hole drilled to fit a 12mm bolt throught the floor and reinforcing plate as advocated by RS in the build videos.
    1 point
