366 -
Everything posted by deano266
HI guys, I am wanting to create a new tunnel cover for the superspec, i am thinking about using sheet metal but before i do are there any other ways (easier and smarter) that has a low profile TIA
i bonded some big head bolts with fiberglass to the back of the dash, sikaflexed some l brackets and attach it using wingnuts
i swapped out the sierra unit for a lucas mini wiper unit. best decision ever
Well the drivers side was not too bad but the passenger's side I gave up and got the grinder out. On a positive they're both out now
Hi guys. What is the best way to remove seats from a 2b Superspec Dean
Hi guys, What are the front suspension bushes from as well as the inner sleeve that goes through them. Also, where can you get them from as i need all new for one side after the accident Dean
@richyb66 we are going to look at putting box section in place of the flimsy brackets. Should sure things up a bit
@richyb66 You were spot on the bracket is all twisted and out of shape. I need to either bend it back using heat and a bit of persuasion or make a new bracket completely. Which would potentially be easier or is there a bracket that can bolt on/weld on
What else could effect the Camber?
Hi guys after having a knock in to a kerb and damaging the wheel and tracking I am just wondering how to alter the Camber at the front. I have sorted out some new wheels that needed a spacer adding but that is all sorted now and they are quality pieces. My issue now is with the tracking and camber. I have set the wheel so it looks like it is pointing in the right direction but the Camber looks off (the top is pointing out and the bottom is in). How do you adjust this or could this be some further damage that I can't see as the chassis and suspension arms all look ok after a visual inspection. It hasn't moved since the incident could that also be an issue with the wheel not lining up correctly
Cheers Geordie but we have sorted some alloys out managed to get 4 matching ones but just need new tyres
Hi guys. I had an unfortunate accident today whilst out. I hit a puddle, spun the back wheels lost control and hit a high kerb. As a result I have destroyed a front alloy . My question is does anyone have a spare front wheel or two of the superspec arays. If not does the offset matter too much as I wouldn't mind a set of mini lite style wheels .
After a thorough go through it would look like maybe one of the plugs in the back of the hazard switch was a little loose and may have caught something. So to help I have coveres them all in shrink wrap to avoid it
The main way is turbo, but that would require alot of reworking not to mention the upgrades to the internals to handle the power (most likely). The other option would be to get an engine that already had the turbo from factory if you wanted to keep the t series style engine
Well thats just rude of her, does she not know that kit cars are never finished
No idea as im not aware when it does go but the left indicator has tripped a fuse so must be shorting out. i had some from demontweeks that were fine and then went and then i splasehd out for the red led indicator relay from CBS
As in was working and now not working
Hi guys. For some reason my superspec has been blowing indicator relays like fun. I have had a 30w one and that seemed to be ok but then today that also went pop. I'm using the premier wiring loom without a hazard relay. Could that be the problem?
Hi guys. Recently my Superspec has developed an interesting quirk. Some days the fuel pump will activate on the key like a good car should. However some days it won't prime unless I attach the fuel pump wore to a live wire momentarily to fire the pump up and then it will run no problem. Does anyone have idea what could cause this. I have swapped the relay for the ECU one and same result
Hi has anyone had any issues with the indicator signal on the premier wiring systems from the relay. I have replaced the switch and the relay and can get a signal when the stalk is moved into position but I am getting no lights Thank you
Hi does anyone know what the spring rating that came on the zimmeride shocks for the superspec and would upgrading the sprig make it much stiffer as it is very bouncy at the moment due to soft springs
what i found with mine is that the mulit plug to the lucas motor is very loose. It might be worth checking there first. if not have a look at your intermittent relay ( if you have one, i personally don't) as it can be very easy to catch and pull those plugs loose
I have a non turbo variant and I have two thermostat plugs. One (the top) is for the ECU to sense the coolant temp and the second (bottom) is as you say for the dash. Personally I would put a bleed valve in the highest pipe so potentially the one that goes at the top of thermostat to the radiator as most installations have the water bottle feed point below this
If the louvres on the bonnet don't work try putting some vents or scoops in the side of the body to get cool air in and out
