3,753 -
33
Everything posted by Grim
The idle control valves are well known for sticking, could it be yours is stuck open? worth removing and cleaning. I've never had an issue with a high idle, other than when there was an air leak. Also check the throttle stop on the butterfly.
July's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 3rd
June's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 5th
May's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 1st
I think i'll miss it, it's the boss's birthday!
April's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 3rd
March's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 6th
February's meet is at Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 6th
don't know what you're talking about
January's meet is a week later than normal, by popular demand... at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 9th
December's meet is at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 5th
i'm aiming to be there a bit early for some food this week
Topic bump because i created it a week too early then hid it in case of confusion (additional to my own)
November's meet is at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 7th
Steve, maybe i dreamt it, was a while ago now
Is it not just engine breathing? The Pintos are fairly heavy breathers but your compression test figures are low, did you do it with the throttle wide open? I got 160-170 when i tested my old engine. Andy
I've got access to a press, but that would require removing the whole arm, hub, brakes etc, which is a much longer job. A two leg puller could also be used if i had a bespoke plate, which is what this tool does, but would take time to make
Has anyone got a ford focus rear suspension bush remover i could borrow/buy, as per the link below. Seems like a lot to spend on a single use tool, so thought I'd check here first. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F253712686998 Andy
Just a thought - i had a crack in my exhaust in the perforated tube which resonated at certain frequencies, and gave a rattle that sounded like pinking.
Octoiber's meet is at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 3rd
If it's the video I think it is, they've got a test rig that moves two halves of a bolted joint. A properly designed joint won't have movement of the two halves as the clamping force exerted by the bolt would prevent movement. It shows that the nordlock washers work well in badly designed or improperly torqued bolted joints, which is certainly a good thing, but not a game changer for most applications
September's meet is at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 5th
be a little careful with your radiator install - with radiators mounted with the fins horizontally like yours, the effective size of the rad is reduced. This is because there's nothing to prevent hot water just going through the top of the radiator, leaving a cold bottom, which doesn't add any cooling. I would be happier with a smaller (thicker if needs be) rad with vertically oriented fins, so that hot water is pumped top to bottom, through the whole area of the radiator. Andy
August's meet is at: Monk's Bridge Farm Nobel Way, Dinnington, S25 3QB Coming eastbound from the M1 J31, take a left at the roundabout by the red lion and proceed for nearly 2 miles, and Monk's bridge is the 4th exit off the next roundabout. https://goo.gl/maps/TcekDG8AHPQ2 Usual time of 7:30 on wednesday the 1st. I wont be able to make it this time Andy
