zerorace
Everything posted by zerorace
  1. zerorace
    Small Compressor
    i have just got one of these http://gtair.co.uk/air-compressors/1-burisch-bt-390t-90-litre-3hp-belt-drive-air-compressor.html
  2. where does it come from then duck is it magic and just keeps refilling LoL
  3. car builder solutions page 263 for resistor and flasher
  4. is it just me then i park a long way from the store on my own come back and there i someone parked in my door handle both sides normally and clear spaces all around
  5. zerorace
    Mazda 2.3
    Hi All Has anyone tried the mazda 2.3 head on a 2.0 zetec block just curious as it has bigger valves or would it be more a kin to the duratec
  6. if you have it short put a heavy gear knob on it
  7. zerorace
    Brake Bias
    thanks for all the reply's will double check clearances on the clevis joints and go from there
  8. zerorace
    Brake Bias
    Thanks nigel no handbrake fitted so I think you have confurmed what I had thought larger rear master cylinder to start with and try again it is only just over braked on the rear will let you know when I get it out again about March or April Bedford Autodrome thanks again
  9. zerorace
    Brake Bias
    from memory 60mm granada cosworth front calipers and disk rear sierra front 60mm calipers and disk front master cylinder .625 rear master cylinder.75
  10. zerorace
    Brake Bias
    Thanks Do You Have The calculation please
  11. zerorace
    Brake Bias
    hi all just a quick one i have the bias bare all the way to one side to reduce the rear brake pressure but it still locks the rears to easy would the next size up master cylinder do the job do you think at the moment i have .625" on the front was.75" and .75" on the rear changing from the .75 to .625 made it better as when they were both the same size the rear bakes locked first.
  12. thanks lotuspaul have had a look around know and found some so bought two for my other classics. zero race
  13. hi lotusPaulwhen did you get it i cant see it on there web site. thanks
  14. try the bay seal kits and complete and remember the sierra calliper was fitted to other cars and bigg red
  15. might have oil but is it the right oil
  16. zerorace
    V6 Bob Engine
    if you run the bob engine with the stock inlet you really need a ecu that has a form of vvt to control the valve in the back of the inlet manifold other wise you will have a flat spot at around 2800-3500 rpm
  17. Just don't forget if you push the bell housing back you have to move the cluch release bearing forwarded the same amount as the spacer so hole in bell housing may need changing or the release arm and the bearing carrier in the front of the gearbox may need to be extended Each and every action has a reaction
  18. zerorace
    Dip Stick
    Thanks Richard
  19. zerorace
    Dip Stick
    hi all does the 2.0l black top dip stick have a "o" ring round the top in the groove just under the pull ring. thanks
  20. Second that great day run all day no problems
  21. zerorace
    Alternator
    HAVE A LOOK CAR BUILDER SOLUTIONS PAGE 209
  22. Try this link it may help you http://emeng.mithosting.co.uk/Cooling/CoolSys.htm I know it it zetec based but all cooling systems have the same principle
  23. zerorace
    Oil On Plugs
    If you take the rocker cover off you will be able to see the valve stem seals if you have a look at them you may see small cracks round the valve stem where they have age hardened it is a age thing not mileage.
