clive5550
    68
4 Neutral
About clive5550
  • Rank
    Getting there Builder
  • Birthday 01/08/1964
    Brantham
  • Interests
    motorsport
    robin hood 2b converted wishbones
    clive hart
3,568 profile views
  1. clive5550
    Weber Dcoe Part
    Hi thanks Bob I've tried both of those and Webcon,fast road cars, and carburettor specialist.com all with the same answer that the part is no longer available i just wondered if someone had got an old carb somewhere as I say if you don't ask but it seems as though it's going to be plan b whatever that is ! Thanks
  2. clive5550
    Weber Dcoe Part
    Hi, no its not number 4 apparently after a bit of research it's off a weber dcoe 40 type 34 they are a old carb and the part is no longer available so not sure how I'm going to get it sorted thanks Clive.
  3. clive5550
    Weber Dcoe Part
    Hi thanks for replies where can I find this Alex pink please Barry.
  4. clive5550
    Weber Dcoe Part
    Hi all bit of a long shot I know but if you don't ask and all that...... has anyone got the castellated ring that sits on top of the carb on a weber dcoe under the jet inspection cover thanks Clive.
  5. clive5550
    Rear Coilovers
    Hi kerry that sounds interesting about changing to a rose joint have you anymore info and where did you get them from ? it would definitely help me thanks Clive.
  6. clive5550
    Rear Coilovers
    I think Bobs got it, for the bottom bracket I'm using the hole in the centre of the trailing arms as a securing point I've obviously got to move the bracket over sideways in the cup so I can get both brackets lined up better thanks everyone for your thoughts Clive.
  7. clive5550
    Rear Coilovers
    Thanks for replies when I say they don't line up they are not out by far but you can see they are not running square and the bolt is nipped in the bush which will probably lead to wear. As soon as I turn the top bracket it releases bolt and it seems to be a better position.The photos from tractor are exactly the same as my set up I just wondered if there was a problem with using the coilovers that way.
  8. clive5550
    Rear Coilovers
    Hi im in the process of converting my rear suspension over to rear coilovers, Ive purchased brackets and a set of coilovers from dave at dampertech. My question is due to the top and bottom bracket not being directly in line, is there a problem if the coilover top and bottom mounts run at 90 degrees to each other. If they are run in line with each other with the arm at the correct running height there is a lot of interference fit on the top and bottom bushes which is released when I turn them to the 90. I have the bottom bracket running in line with the trailing arm but its the top bracket that slides into the roll bar hoop causing the problem thanks for any help clive.
  9. clive5550
    Pinto Oil Breather Cap
    Hi all I'm after a oil filler cap for my pinto engine I'm after the one with a spigot on to run a breather pipe to my catch tank thanks Clive.
  10. clive5550
    Gargae Clear Out
    Pm sent
  11. clive5550
    Gargae Clear Out
    Hi John are the rear wings still available and would you be able to post please thanks Clive
  12. clive5550
    Dizy For A Pinto
    Hi Mick the oil came from the stem of the dizzy it was two ali parts pressed together the two became loose and therefore there was play the oil leaked out of the loose joint, at the time I removed it I had enough play to turn the top half/cap early 1/4 inch each way with the body still bolted into the block.
  13. clive5550
    Dizy For A Pinto
    All I can say is it was advertised as that, it cost in the region of £80 so I was just saying to be careful.
  14. clive5550
    Dizy For A Pinto
    Hi just a word of caution I bought a accuspark off eBay it lasted about 18 months and not many miles approx 1500 and it leaked oil out through the body casting.No one would repair it as it was a "cheap Chinese import". I'm now running a bestek system loads better and with full guarantees cheers Clive.
