tractor
Everything posted by tractor
  1. defo sounds like a tune up wouldnt go amiss
  2. tractor
    Presents
    hmmm presents
  3. yes had a great evening i think all of the leicestershire massive will miss you maybe when the AZBO is lifted you can return to leicester
  4. mine didnt have front anti roll bar
  5. yes i see the difference now mine was a 2b/04 and it wasnt like that if you raise the engine as high as poss and cut that cross member out it should fit i reckon i raised the engine on mine i had to flatten the flanges in the middle of the bonnet cos i had raised it so far that the bonnet sat on the cambelt cover when closed
  6. dont know about the raceline sump but i assume it will be nearly the same size as wot i used i had to cut the plough off its not structural anyway
  7. tractor
    just testing
    so if i get a smaller phone to take pictures will that help
  8. tractor
    just testing
    just getting lazy in my old age its such a faf having to use a host site just to post a picture
  9. tractor
    just testing
    nope didnt work still cant upload pictures
  10. i put the engine and gearbox in and used blocks of wood to get it to sit in the right position i then got the diy zetec mount kit from retro ford cut to length then tack welded then removed mounts from the car and welded them up my zetec had a flat sump so it sat nicely on the blocks of wood it was a while ago now so i dont have any pictures
  11. tractor
    Zetec Sump
    i think premier motor sport do a reasonably priced sump
  12. tractor
    Ecu Zetec Blacktop
    A few people have got the megasquirt 2 which is fairly cheap and loaded with a Base map and a very good tuner at Bailey performance if you don't want to tune it yourself
  13. tractor
    Ecu Zetec Blacktop
    depends how deep your pockets are
  14. tractor
    Zetec Swirl Pot
    swirl pots in the engine bay have there own issues especially on hot days just ask Andi
  15. tractor
    Zetec Swirl Pot
    the 2b tank is an ideal candidate for the in tank pump and swirl pot and then theres only two pipes to worry about
  16. yep looks good makes the back end look finished
  17. as with all insurance and warranty products the paper its written on is worth more
  18. It was a tad chilly but I was well wrapped up
  19. Nah its never that easy Mat something will go wrong and you will have to take it all off again
  20. tractor
    Which Head
    The injection head is better than the standard head so I am told
  21. tractor
    Great Weather
    i took my kit to work today although at 6am i did wrap up warm for the drive to work
