SteH
    39
SteH last won the day on July 14 2015
SteH had the most liked content!
8 Neutral
About SteH
  • Rank
    Builder
  • Birthday 08/14/1975
    2B
    Ste Hoyle
    Rainford St.Helens
  1. Plus... A non adjustable Sierra steering column complete with Moutney steering wheel - £45 plus £10 delivery A height adjustable Sierra steering column complete but no key. £45 plus £10 delivery. A pair of polished stainless stone guards unused with protective film still on. £10 plus £5 postage. Leather Sierra steering wheel "very good condition for age" £15 plus £5 postage. Robinhood supplied wing mirror. Dusty but unused. £5 plus £5 postage Brake or clutch pedal - no idea what it's intended for - FOC plus £5 postage Pair of mild steel
  2. The seats are now sold. I also have for sale: A pair of unused never fitted Sabelt black 2" 4 point harnesses with aircraft style buckles. £75 plus £10 delivery. Used aluminium fuel tank. Approx dimensions - 75cm long, 17cm deep, height 20cm rear of car side increasing to 22cm front side of car. It has outlets top and bottom plus filler. There is a sender fitted, but i have no idea what it is. Two steel straps are included as per picture. £50 plus £15 delivery.
  3. No I've still got them, never got round to re advertising them. PM me an offer if you're interested.
  4. A pair of Sierra rear hubs - uprights and stub axles for disc brakes. These have been cleaned up and painted. They will come with a new set of bearings that will need pressing in. £90 collected from WA11 8LY or extra £15 to send by Courier. A pair of 100mm diameter lobro bolt on half shafts. These have new boots fitted and just need a light clean up and paint. £50 collected or extra £15 to send by courier.
  5. Used aluminium fuel tank. Approx dimensions - 75cm long, 17cm deep, height 20cm rear of car side increasing to 22cm front side of car. It has outlets top and bottom plus filler. There is a sender fitted, but i have no idea what it is. Two steel straps are included as per picture. £60 collected from WA11 8LY or extra £15 to send it by courier.
  6. Loom and Haynes sold Seats still available
  7. Might be possible to DIY with parts from Intatrim, or get them to do it?
  8. An unused pair of IntaTrim Odyssey seats in black vinyl. See http://www.intatrimtelford.co.uk/index.php?option=com_virtuemart&page=shop.product_details&flypage=flypage.tpl&product_id=21&Itemid=26 for specs. These have never been fitted so have no holes in them etc. I suspect that one is slightly older than the other as the vinyl is slightly more shiny than the other, but with a good clean I'm sure they would look more or less identical. I also have an unused set of low profile runners that I can include if required. £185 plus an extra £25 for delivery, collection from WA11
  9. I think probably not. Have a look at http://www.locust.org.uk/knowlegebase/gearbox/ups_n_downs.htm . Looks like the 5 speed is longer and the output is bigger with a different no. of splines.
  10. Set of 4 Team Dynamics Pro Race 1.2 alloy wheels in gloss black with Toyo Proxes R1R tyres. The wheels are 7Jx15, PCD 4x108, ET35 Tyres are 195/50R15 The wheels and tyres are in excellent condition having only done about 1000 miles. No damage at all. The wheels have just been re-balanced with black weights - some of the original weights had fallen off! Tyres all have 6mm tread. £350 plus £25 for delivery - collection no problem from WA11 8LY
  11. A pair of Gaz adjustable shocks, length 16" open, 11.5" closed with 300lbs springs. Suitable for the rear of a 2B. These shocks were fitted to an unfinished kit, but have never been on the road. Some very light surface corrosion. £100 plus £10 postage. Collection welcome for any items. A set of top and bottom mounts for Gaz shocks for the rear of a 2B. Fitted but not used on the road. One of the bottom mounts (the smaller u shape) is damaged and will need a weld repair or replacing. £25 plus £5 postage. Prop shaft for a 2B - Type 9 5 speed gearbox to sierra diff - again fitted
