Oscarborder
    27
0 Neutral
2 Followers
About Oscarborder
  • Rank
    Builder
  • Birthday 07/14/1944
    Ramsgate, Kent
  • Interests
    Outdoor bowling, fishing and walking my 2 dogs.
    2B sliding pillar
    Gerald Short
  1. Oscarborder
    Help In Derby Wanted
    Hi, the Delonghi Coffee maker is at DE1 3LQ if this helps any member to assist me Regards Gerry
  2. Oscarborder
    I know it is not car related but I would like someone in Derby to collect a Delonghi coffee maker and allow me to send a parcel courier to their home/work to enable them to collect it for me. Edit by Mods: This gentleman is a Full Member of RHOCaR so please treat as such. Thank You.
  3. Oscarborder
    Front Mudguard Bracket
    Thanks Al, are you in tomorrow evening about 6?
  4. Oscarborder
    The front mudguard bracket supplied with my part built 2B appears to be for the long cycle wing. Has any one got a pair of brackets I could copy or could someone make them for me, naturally at my expense.
  5. Oscarborder
    2B Front Suspension Assembly
    The front suspension on my 2B appears to be incorrectly assembled as the mudguard bracket is not there and I have noticed something that looks like filler foam at the bottom of the suspension. I have also found in a bag 2 steel tubing mounts, 6 nuts and bolts and a note from RH stating that these mounts should be fitted to the bottom of the chrome steel tube. Has any one got a detailed assembly of the suspension.
  6. Oscarborder
    Fuel Tank Breather
    Thank you to both Snapperpaul and Ian & Carol for their most useful information which I will use when I return to the build next week. Regards Gerry
  7. Oscarborder
    Fuel Tank Breather
    Just fitted a stainless steel tank and about to fit a breather pipe into it. Can the breather pipe be fitted so that it terminates 50 mm below the filler cap with a bend pointing back to the tank?
  8. Oscarborder
    Windscreen Rubber Specification
    Thank you for all your replies which will help me yet overcome another 2B nightmare.
  9. Can any one top advise me on the width and thickness for the windscreen rubber that fits into the Windscreen channel for the glass to sit in?
  10. Oscarborder
    Front Cycle Wings
    Thanks for your replies but I've sourced a pair locally
  11. Oscarborder
    Front Swept Style Cycle Wings In Brg
    Hope this photo helps
  12. Oscarborder
    Chrome K&m Or Similar Air Cleaner
    Yes please, how do I pay you? Regards Gerry
  13. Oscarborder
    Will take some pictures tomorrow
  14. Oscarborder
    Chrome K&M or similar air cleaner wanted for Weber 2V 28/30 DFTH carb.
  15. Oscarborder
    Pinto Engine Angle
    Thank you for all your replies it has certainly reassured me.
