mickw
Everything posted by mickw
  1. Is swapping a 1.6 pinto for a 2lt just a straight swap? Or do other items such as clutch, flywheel, bell housing, starter, alternator inlet or exhaust manifold need changing or modifying in any way.
  2. mickw
    Pinto sump
    Hi has anyone got drawings or instructions for shortening a pinto sump
  3. Can anyone help me please. I have a 2b with 1.6 pinto that won't start. Turns over great,as far as I can tell the ignition system is working. Thought it might be fuel or carb, so checked supply to carb and it seems to be OK. If I spray damp start into carb it starts and will run until damp start is used up. If I start car and carry on spraying it will keep running. Any ideas
  4. Can anyone help me please. I have a 2b with 1.6 pinto that won't start. Turns over great,as far as I can tell the ignition system is working. Thought it might be fuel or carb, so checked supply to carb and it seems to be OK. If I spray damp start into carb it starts and will run until damp start is used up. If I start car and carry on spraying it will keep running. Any ideas
  5. has anyone tried the boot cover from kit spares?how good are they? how easy to fit?
