665 -
9
Everything posted by Dean Roberts
Some pictures of the cars attending the Canal festival: http://s1275.photobucket.com/user/Dino2B/Moira%202016/Moira%20Cars/story And a snippet of the above link:
Isn't that what most women say?
Drilled and grooved look pretty with painted calipers. But bigger 260mm seem to sit better within a large alloy wheel. Oh the choices.....
Front Disk Brakes - 260mm vented VS 240mm grooved, drilled & vented. Who wins?
Brake Upgrade Options & Ideas
Dean Roberts replied to Dean Roberts's topic in Maintenance & Modifications
I normally use a brake cleaner and small wire brush to clean up brakes, but somebody at work suggested cleaning the drums with boiling water to remove the residue. He said just get a bucket of boiling water and place the drums in and the brake dust will evaporate. Is this true or just another fairy tale? -
Just got to get into wet leaking garage and can confirm.... Flood lights don't work. Floor is wet. Roof is leaking... But more importantly the cars are OK Master cylinders are as follows: Front - 0.625 Rear - 0.7 Front brakes are 240mm vented disks Rear are smaller 1.6 drums with slave cylinder leaking and very, very dirty yet the spring and shoes look very good (after cleaning). Dave informs me all the brakes are good to go and the shoes etc. were updated in 2013. So it looks like I need to replace smaller, tired worn out drums and cylinders before moving forward. Luckily as per Ian's suggestion I already have a donor car onsite for testing -
Ian, were they off a Ford Granada or XR4? -
Mmmmmm....trying to remember on the sensor and the figures. Front brakes were reading different values possibly something like - Drivers side 160 Passengers 130 Rears Brakes: Never got over 50 and I do remember them laughing and the tester saying the handbrake was also rubbish. I will try cleaning up the rear drums and replacing the slave cylinders (especially if they are leaking), bleeding and double checking the bias bar set-up. Then back around to the rollers to see if this improves things. BRUM - Any way of identifying the duff slave cylinders from the good? -
Nutta -
Hmmm....Just had a good read thru the discussion and can definitely confirm that no matter how hard the brake are jumped on - none of the brakes will not lock up (maybe a good thing). But on the flip side they also take an age to slow the vehicle (mainly the front disks doing all the work) According to the rollers on the MOT centre, the tiny front disks barely passed and the rear drums were non existent. I removed the drivers side drum last night and found a leaking cylinder and hoping that this maybe be the issue. Tonight I will have a look at the passenger side drum and give a little more feedback on some of the questions being asked. Highly appreciate the feedback. So it looks like the consensus is to fix what is broken and get it working properly now, then maybe look into upgrading to something cheap, reliable and better once the problem has been resolved. Damn you BRUM - I was about to order 2x of those £10 slave cylinders off a famous auction site....... -
Grim, my good friend. It all stems from the MOT and front and rear brakes not being up to scratch for the 240bhp engine. The tester failed the car and recommended I upgrade to better brakes or at least fix the problem with the rear drums not working....(leaking cylinder). So to get it thru the MOT I was going to clean the drums, replace both cylinders and bleed system as the springs, shoes etc. are still very good and were updated in 2013. No matter how hard I hit the brakes it will not lock up (which I would expect when intentionally trying too) and not very responsive compared to the rest of the car. Nikki and myself are very happy with the firm feeling (ooeer missus) and this is not an issue, not even had enough road time to experience brake fade from heat. But my 2 tonne 4x4 is more responsive and that takes a lot of effort to slow down, and this is a quarter of the weight and takes a lot longer to stop with effort. No Servo, but brake set-up looks like this: -
OK Kids, I have a Robin Hood 2B based on a Sierra 1.6. Now it's has plenty of poke with a 3.0 V6 but won't stop. Meantime to get it thru the MOT I will need to replace a few bits and bleed the braking system on the drums (leaky cylinders etc.) But I think the measly 1.6 drums and disks are not up to the task of stopping the beast of Brum when a granny steps out at the crossing. Front Brakes: So I'm asking for options for upgrading the front brakes and recommendation of where to purchase. Example - (Wilwoods 4 pot etc....) which do not break the bank balance. Can I just purchase bigger Cosworth/4x4/2.0 front brake disks (from auction site) and calipers and replace the 1.6 versions. Rear Brakes: Well after opening up the rear brakes on the new kit last night and comparing them to my older 2.0 based kit I noticed the drums are far smaller. During the sorn period It might be an opportune time to upgrade the rear brakes. What are my options? Can I just swap the 1.6ltr drums to 2.0ltr drums Or should I upgrade to rear disks and calipers as I have to remove the old worn out/small drums?
A bit of info for anybody interested in a nice family weekend out: http://www.moiracanalfestival.co.uk/ https://www.facebook.com/moiracanalfestival/ https://www.youtube.com/watch?v=qVYIFbeYTos http://www.ashbycanal.org.uk/moira-canal-festival/
Some links to picture information etc... for anybody wishing to attend and wondering what its all about: http://steamonrutlandwater.weebly.com/ https://www.facebook.com/steamonrutlandwater/ And a bit of video footage: https://www.youtube.com/watch?v=OCt1_R2hUcE
Thanks Derek, we await the passes. Would be nice if this becomes a regular event as it was shocking how the weather, (charges for the sellers and lack of promotion) deterred so many attendees at the Stoneleigh Show.
Nothing serious and I have a 4 wheel incentive to recovery quickly.
I think she has answered the question.......Smooooooth and stylish, with a deep growl when something gets in the way... I do love Nikki's first mod to the Kitty, a no brakes sticker on the dash board to remind her.... As soon as the quacks sign me fit to drive and the sun shines, it will be my turn....
Yes, it was returned to its trusty home last night. Thank you very much Rich, greatly appreciated - I owe you a drink or 2 or 3...
Keith & Chris, how did you get on with the RR?
Nikki has this booking been confirmed and do we need any promotional material from Phil etc..? Are there anybody else interested in this event and it seems to have got lost in the posts and nobody was aware.
Andi do you have any flags or promotional material for the event?
A big thank you to Dave and his family for looking after us yesterday. We couldn't wish for more, beautiful weather, great car and a little insight into Dave's creative mind. I just need to now hide the steering wheel and keys from the wife...
First full, sunny weekend at home and I end up......not at home. A full weekend of living on the motorways, country lanes and duel carriageways.... Approximately 700 miles covered - Coventry, Tamworth, Leicester, Burton, Derby, Nottingham, Chorley and again after work tonight back to Derby. A fully enjoyable time with the 4x4 and towing different items back and forth to sunny Brum. By the time I sat down to have dinner last night at 20:30, I was completely exhausted. But at least the caravan and the Kit have new family homes. Went to work today and got this email from the wife and then a security picture: I quote Nikki, "I'm in love she purrs !" Aaaaaaaarrrrrggghhhhhh.....didn't take the wife long to get attached to new baby. Oh well, looks like I'm nominated caravan driver again for all the RHOCaR shows.....
Stoneleigh 2016 National Kit Car Show 1St 2Nd May
Dean Roberts replied to philshelton's topic in Events
Big thanks to all the guys & girls for looking after us all. Looks like not getting the road tax on the kit - paid off.... An extremely expensive, but deserved weekend....Considering we were visiting the show to see all the friends and family and order a surrey top for the kit.... ...Well we got the surrey top, but now need a bigger garage...? Absolutely exhausted and going back to work ( sorry for swear word), to pay the bills and have a rest. -
Nope just making sure everybody gets too stuffed to eat the hog roast and burgers...then that leaves more for me....yummy
