277 -
12
Everything posted by Pintogogo
Yeah I agree Alan it would be a shame to let it go, crack is good and I picked up quite a lot from the guys that go, i'm off for another week and its only shifts that hinder me (but hopefully not for much longer lol) is anyone meeting tomorrow at the church mouse ? if so post on here n I will be there Harry
Hi Alan Thanks for the reply and I too hope we can keep the meetings going I enjoy the varied chat, Have a great xmas and a happy healthy prosporous 2017 Harry
Having been out of the loop for the past 3 months due to shift work, is there any meets planned for over the festive period, I hope so, if not:- Seasons greetings to all Members & Friends Stay safe and have a Happy, Healthy 2017 Best wishes Harry
It was good a good turnout & enjoyed the banter, the kit actually had no probs this time bar the timing not being spot on ,but some good advice from Alan might put that right when I try it. Cheers all, see you next month (hopefully)
LOL I know hahaha itll be confused due to bank holiday
See you all there
Hi Guys Thanks for the help, I have a Std cam & an accuspark dizzy Harry
Hi guys,, Ive tried several times to get my Pinto timed correct using strobe, vacuum pipe disconnected @1000 rpm each time and when I go around the 12 deg BTDC it loses a bit of top end pulling power & pinks a bit and around the 10 deg BTDC it seems to run better but backfires through exhaust (or sometimes carb) when swiitched off Any Ideas Cheers Harry
I'm on my annual holidays Alan n will be at home so will deffo make it ( hopefully in my Hood ) been a while since I saw you all be good to catch up. Take care see you there. Harry
Hi Im after a pinto 2.oL unleaded head, n twin webbers if you have any Harry
Sorry I missed out again chaps, Ive just got in n its 7.30 pm n I'm knackered, by the time I get a shower , something to eat n drive through it would be late, gutted at having to miss meet I enjoy the crack, see you all next time Harry
I'll be there Alan Kit up n running again hopefully it keeps going lol if not I'll be in tin top See Yawl next Weds Harry.
Thanks Bob, so looks like Ill have to get shaft out to compare?
The outer cv joint of my S7 offside driveshaft boot was loose, on inspection there is a 'loose ring' inside the boot on the shaft, this appears to have been what the boot was fastened to. Can anyone help with the following What is the easiest method to remove driveshaft (push in type) Are there different shafts that ford used or is it a common shaft, my offside shaft measured 22" from diff to brake drum backing plate Where is the best place to obtain a replacement driveshaft Thanks in advance Harry
I have just purchased new shockers for my S7 as the old ones both had the rubber bush in the top eye separate from the metal eye, leaving the bush bolted to the mounting and the shocker eye floating half on the bush and against the fiberglass rear arch causing a Knock on both sides. The shockers currently run from the bracket at the back of the drum brake to the rear top corner of the wheel arch at an angle of approx. 50deg. This is the original set up but I don't want the bushes on the new shockers to separate from the shocker again so 2 questions :- (i)Would it be better to mount the shocker in a vertical plane straight up above bottom mount (ii)If mounted in original position, what can be done to prevent 'pivoting forces' ripping the rubber bush from top eye, short of not bolting up tight Thanks in advance for help Harry
Hi Guys, Sorry I can't make it due to work commitments, pity cos weathers on the up, I hope to see you all next month Stay safe Harry
Same thing happened with my Nissan primera. turned out starter motor was shagged n engaged all time flattening battery whilst driving and when swithched off would continue to turn engine until battery completely flat, recon starter solved problem, hope this helps
Had similar problem before on my tin top, Battery keep going flat then running when key removed.. turned out to be starter motor bendix jammed so starter motor was running all time - pulling power from battery then it kept running when key was taken out, turning the engine over as though it was still running.
Sorry guys can't make tonight Last minute shift change today days to latex hope to be there March Enjoy ya night
I'll be there Steve all being well, see you all weds
Thanks but I have titanium elbow joint after suffering an accident, I am 90% there but its the stretching to change gears that gets me (i'm only a little fella) & I thought it might be easier if lever was closer.
I have a S7 and a false elbow joint, I was wondering if anyone has fitted one of the RMD gear change linkage plates from flea bay that moves the gear lever position back 130mm on a type 9 box and a short shift lever & if so did it make any difference
I cant make it Alan I'm on lateshift this week, gutted!! Hope you all have a good night n I hope to see you all next month Harry
As everyone says, Make sure car is legal & says ROBIN HOOD on log book, not sierra etc, loads advertised on e bay with no IVA n just donor plates fitted, you can still test,tax n Insure them as details just come up as donor car but if you have an accident well ........... Honest check thoroughly before you buy.
Hi Guys Glad you had a good run out, gutted I missed it but daughters car broke down & I ve had mega prob with it, OBD said NATS fault, turned out its brain had been wiped n was estimayed at £700 - 1000 to fix depending on ECU, chips etc - Now p/x BEST WISHES FOR A HAPPY, HEALTHY 2016 Harry
