Turboz
Turboz last won the day on March 6 2016
Turboz had the most liked content!
About Turboz
  • Birthday 01/02/1975
    Gbs zero
    Steven arnold
    Derby
Turboz's Achievements
Builder
Builder (2/5)
6
  1. Woah that's some serious torque at low revs I'm guessing it's not a centrifugal supercharger then is it a roots or twin scroll. I'm not making that torque till 5500 rpm even with a turbo (obviously designed to hit Max boost at 8500 rpm) Live axles aren't the best for putting power down but there's still a lot to adjust that could help
  2. If your struggling for grip under 300bhp with pilot sport 3 you need to have a serious look at suspension geometry possibly new suspension and your diff if it's an old Sierra lsd it will need a rebuild if it's open diff go for a plated locking diff.
  3. I'm up for that any of those dates work for me.
  4. I was hoping for 10s myself, but I didn't account for the grip of a sticky track and hot slicks (hence the diff exploding) I may try again this summer now I have a 9inch cosworth diff May need a wheelie bar though.
  5. If you do go to the drag strip make sure you have a full cage or you will be banned if you run a sub 12 seconds. Its also very harsh on your drive line I killed my 7.5" lsd shifting from 1st to 2nd and dropped oil on the track, I wasn't the most popular guy there let me tell you. It did wheelie off the line witch was also unexpected.
  6. At 280 you'll be twisting the crank as well as snapping con rods. Hope it does hold up for you there's nothing worse than sending a rod through the block. As for putting the power down you'll be fine with a plated lsd (I can't get on with a torque bias diff like quafe atb) and some sticky tyres like r888's. I've had to swap to Sierra 9" diff with wave track lsd as the 7.5" diff is only good for around 500bhp had to chop the rear end up to fit the thing in though.
  7. How much stronger though 5-10% ? Nothing like the 75% gain they have made, I'd be looking for aftermarket, it's easy to obtain con rods rated at 250 bhp per rod nowadays.
  8. Hi guys some serious numbers there, are you running forged internals, when I was running running a 205 bhp on a new zetec black top (naturally aspirated) I noticed a drop in power over time, did a compression test found it to be down, it turned out to be 2 bent con rods. I think anything over 180 bhp starts to bend them it's only a matter of time on standard internals.
  9. Hi there a few questions. what engine what size injectors what boost are you aiming for
  10. Are you running an aftermarket ecu if so you don't need the maf sensor it only helps get that last 5% fuel economy that's all, tps and air temp alone are fine.
  11. hi all i saw a test a wile back on oil filter flow restriction / pressure drop and all of the budget filters wix, plue print, fram ext... did really bad pressure was way down. k&n were near the top and still affordable.
  12. That looks more like it, thanks mate. Cooling shouldn't be a problem I'm using the same radiator as in my car a custom 5 row aluminum jobbie it keeps my s2000 turbo engine cool.
  13. Oh I didn't mean a DIY job but by a professional prop builder but still it doesn't seem right ?
  14. I've just read that you can weld a front chain ring / sprocket to the front end of the prop shaft but that sounds a bit of a bodge job ?
  15. I've seen chain driven radicals but that's because the engine's in the back next to the rear axel.
