Gusty
Everything posted by Gusty
  1. Hi, Size of engine , petrol/derv? Cheers
  2. Gusty
    Pinto Problem
    Mine was a pig to start until I put a new Bosch 1.4KW starter motor on along with a new battery. Starts great now .
  3. Gusty
    Massive Flat Spot
    Nice to hear you got it sorted
  4. Gusty
    Massive Flat Spot
    Hi, I had issues similar to yours after my car had been standing for 7 years. It was due to fuel, sender seized up, tank full of crap, fuel line degraded . Cleaned tank out , new sender, new fuel line and filter. Problem solved. Good luck
  5. Gusty
    Cylinder Head
    Clayfield& hall Hinckley. Excellent old school work shop
  6. Thanks for the replies. I think one of the center bolts has bottomed out. I will remove bolt shorten by 10mm and try again! Cheers Ps I will report back when I find the time to do it!
  7. Everything was spotless. May try some rad weld!
  8. Nipped up all bolts and still weeps????
  9. Hi all, Coolant leak exhaust side from where the head joins the block. It's only a very slight weep, engine runs and drives sweet as a nut. 100 miles max since full rebuild. Head skimmed, block straight, Victor Reinz Gasket, stretch bolts tightened to the correct spec and procedure. Any ideas please ??? Can I try nipping the head bolts up a little more? If so, to how many Newtons? The last stage with stretch bolts is to turn through 90 degrees which I did. The old type of bolts was to torque to 115nm would this be ok? Any help much appreciated. Thanks Andy
  10. Gusty
    New Member
    Congratulations both. I agree with Steve49er , we dropped our daughter off at Sheffield Uni yesterday . I don't know where the time has gone . Make the most of every minute and enjoy. Happy times ahead. Rgds Andy
  11. Gusty
    Alternator
    Disregard . Just been out to check constant 12.6v then looked at back of alternator and realised it wasn't plugged in!!! What a numpty!! Cheers
  12. Gusty
    Alternator
    Will check later and report back
  13. Gusty
    Alternator
    Hi, Alternator charging at 12.6v on idle. Seems a little low to me?? Cheers Andy
  14. Cheers Longboarder. Just dropped on one. Should be here Tuesday . Thanks
  15. Hi , As per the title please. Cracked mine tensioning the cam belt!!!
  16. Hi, Didn't braze in the end as I thought it may damage the electrical gubbings, so got a piece of ptfe tube. Thanks all for the help. Gusty
  17. Yes I fancy the silver solder option. I'll give it a go.
  18. Cheers guys. I've bought a new sender but the pick up is a little short! I'll have a look around to see what I can get. I've bought all new fuel hose to run from tank to carb but this stuff can't be permanently submerged in fuel! Cheers
  19. These have gone to Dave. Cheers
  20. Hi all, Looking for fuel hose/ pipe that can be submersed in petrol. Basically want to extend fuel pick up on sender by a few inches to reach bottom of tank. Thought of silver solder some copper pipe on to extend but thinking hose and stainless jubilee clip may be easier. Any suggestions? Cheers Andy
  21. Drop a match in it first to clear the vapours then you should be fine to drill it minus your eyebrows:)))
