Matt brown
Posts posted by Matt brown
  1. Thanks, from speaking to another member at the local meet he thinks that there may not even be a thermostat installed and is constantly open so im going to look at that first and fit one if needed then look at adjusting the fan to come in a little later and see how it works , when it gets a little warmer ill be able to check to see if its getting to hot then go from there.
    probably the best image i currently have of the bonnet vents, i would think these would be more than adequate, im going to re wrap my manifold as the person i bought the car off didn't seem to do a very good job and its falling off.
    ill see if i can get a better position for the fan as only around 3/4 of the fan is blowing through the fins, i wont really be able to check it properly until its abit warmer.
    what would be a good normal working temp to try and achieve? as 65 does seem on the lower side and what would be the max temp you would want to run the pinto engine ?
    thanks
  3. Basically I just wanted to know if a push fan is better than a pull fan at first. Then other questions were asked so I answered them to give people a better understanding of the situation.
    I don't think there's a issue as such as in cooler weather I can have it sitting for 20mins with very little temperature fluctuation usually around 65-68, but when the weather gets warmer say 18-20 ambient temp when at a standstill the temperature just keeps increasing about 1oc every 20-30 seconds. It seems like the fan ether can't get enough airflow through or there's to much heat soak from the engine/exhaust.
    Hope that Clears things up
  4. The rad is about 3 inches thick and takes up pretty much the whole width of the front just infront of the frame, hight wise you have to open up the nose to be able to remove the top cap properly and goes pretty much to the bottom of the frame, not sure what the normal size is compared to that
  5. I have a s7 With Sierra steering colum and the hazard switch has broken and won't turn off, I have also broken my lights stalk while removing the dash piece, is there any way of changing the stalks on both sides with a universal type setup as it's proving difficult to find a replacement for the hazard side stalk.
    http://www.carbuildersolutions.com/uk/multi-stalk-assembly
    I found this but was unsure if I could make it work would anyone be able to shed some light on this or suggest a different option. Thanks
    Hope that helps, the fan I currently have pushes air from the front of the car through the rad into the engine bay but is mainly focused on the bottom end of the rad due to space
  7. I currently have a rh s7 with a 2.1 pinto and on warm days you can watch the temperature rise when sitting still in traffic or at traffic lights, now the question is the radiator fan is not in direct contact with the rad as the front part of the frame does not allow it, so is it best to have a fan which pushes air from the nose cone into the rad and into the engine bay, or a fan which pulls the warmer air from the engine bay and out the nose cone? Thanks
