379 -
15
Everything posted by maca
If you have the old V5C in your name then you maybe able to get an age related plate if not then you will get a Q plate Your Address Date KITS & REBUILDS DVLA SWANSEA SA99 1ZZ Reference (registering a new vehicle) Dear Sir or Madam I wish to apply to register a kit car following IVA test. I have enclosed all documents I am aware of requiring along with donor vehicle V5C (registration number F----C) I wish to apply for an age related number of the old vehicle. I have filled in the relevant forms and given answers that I am able to but am not to sure how to answer some of the question details requested. If there are any other details that you require then please inform me of this. I have enclosed documents as below. V627/1 V55/5 IVA PASS V5C of donor vehicle The registration fee £55.00 The road fund payment £245.00 Regards
Watch YouTube (robin hood build video 5) It shows you how to fit the rear panel.
Form IVA 4 INDIVIDUAL VEHICLE APPROVAL – AMATEUR BUILT DECLARATION Fill in this form Question 3 tick Question 4 tick You could state that the first owner has passed away at question 4 Section 2 In the case of items 1-4, please indicate which of the major components below have been fitted to the chassis/body by you or individuals acting on your behalf who are not in the business of building vehicles. Put a tick against questions 1 - 6 Fill in all the other revelant details requested. You may be bending the truth a little. You could also add a few pictures with engine fitted and the wheels removed Ect.
The lip with the spring should be the inward side so the larger side is the outside.
Many thanks for the post Richard on the forum of this sad news I have sent a card to the Family offering the club's condolences on John's passing away. Many of the Derbyshire and Nottinghamshire Members do not read the forum, would it be possible for Neil to add an artical in the next issue of the magaine Regards Martin (maca)
Hi Neil, Couple of questions for you to answer, Do you not have any free play in the cable and you are over stretching it when you are at full throttle causing it to snap? Have you a pedal stop or do you need a pedal stop? Can the cable be repositioned so that you don't have this problem? Can the bracket be spaced off? The cable should never be at full stretch and should have free play at the end of travel.
Contact your Insurance company, explain that you have an IVA Test and your car has not been registered. They will Insure your vechile from the VIN number. They will require you to inform them of the Reg number when DVLA have issued a number after registeration for the vehicle. Expect DVLA to take about 4 weeks to issue a Registeration number to you so that you can have some plates made. That's what I did and had no problems. If stopped show them your insurance and IVA test letter. Regards Martin
Sorry Girls and Boy's but won't be with you at the w/end so did my run out today and found the windmill.
I have to agree with Mark. What you spend on a trailer could go towards your first years insurance for the car. I drove mine to the test centre. You can always have someone with a backup vehicle follow you just in case. Regards Martin
Try MBS trailer hire just did a search on Google https://www.mbstrailerhire.co.uk/
Never did get that drive out, sorry to hear you have to sell the car anyway good look with the sale. Martin
Modified my sump then found after fitting it picked the oil up quicker than what it would return so had to have the crank ground and new bearings. Then fitted the RS 2000/Mexico sump from Burton Power and new oil pump not had a problem since then. Just had to file the baffle plate for the dip stick to line up correctly. https://www.burtonpower.com/alloy-sump-pan-rs2000-rhd-with-baffle-plate-sohc-pinto-ft650.html
From my Haynes Manual Cylinder Head Bolts Splined type bolts Nm lbf Stage 1.............................................................................40 to 45 30 to 41 Stage 2.............................................................................50 to 70 37 to 52 Stage 3 (after 20 minutes)................................................ 73 to 83 54 to 61 Stage 4 (after running engine for 15 min at 1000 rpm)......95 to 115 70 to 85 Torx type bolts Stage 1..............................................................................35 to 40 26 to 30 Stage 2..............................................................................70 to 75 52 to 55 Stage 3 (after 5 minutes)..................................................Tighten through a further 90 deg.
Looks like a Pinto so use 20/50 oil the old school type.
Yes it can be cut in half so as to make easyer fitting without having to remove the drive shaft. I think it had a 1.5 deg. taper in both directions so as to adjust both camber and toe in. Regards Martin
Longboarder did a post last year with some details as below. I purchased a set from Peter Bell when he was making them @ £33.00 a set. That did the caster and toe in for the rear tracking. Regards Martin
I went Saturday morning about 11.00 Sorry to say only one 1963 Hillman Minx parked outside the Cafe that was closed and NO Toilets open. Other then the railway rolling stock very disapointing. The best part was the drive there and back in the car.
I would think that is a matter for the owner as to how big or small the seats are in their car. What may suit one person may not suit someone else it is their taste as to many things and is called individuality.
Looking at your car and the age of it I would say it has a type 9 gearbox fitted. Check if the Bell housing and gearbox are cast iron in looks if so then it is a type 9. The MT 75 is aluminimium.
Watching your video the problem is the starter bendix gear sticking due to the oil/grease around it. Have a look at this video
Take the plugs out put a socket and ratchet on the crank shaft bolt. Then slowly turn the engine and check the ring gear if all is ok then the starter is at fault.
It gives the appearance of the solenoid not pre engaging the gear or the starter ring is at fault. Have you checked the starter ring gear for missing teeth?
Do you not need a rolled edge outlet bend on your tailpipe? To direct the fumes away from the side of the body.
