Patt
    22
0 Neutral
About Patt
  • Rank
    Builder
    2B
    Stuart Pattinson
    Morpeth
740 profile views
  1. Canned it was - got my 2B through IVA at the end of Dec 2018, 2lt pinto, big valve head, fast road cam and a dgas carb. Sailed through the emissions bit no bother
  2. Patt
    Floor Strengh
    Hi Alan, yeah just waiting for reg - could be delayed because of the Christmas hols. We are on holiday straight after new year and hoping for something in the post when we get back. it’s a small world, we lived in Cramlington for 22 years and downsized to a bungalow in Stannington last year. I’m up for a trip out - on a fine day as no hood or windscreen Patt
  3. Patt
    Floor Strengh
    Many thanks to previous messages - yes it is a good feeling. I have to say this would not have been possible without the help of this club and the expertise of its members. I am just a community participant at the moment, but have been a member in the past. I am thinking of joining again as perhaps I can pass on some of the solutions to problems that I have faced And overcome as the build progressed. Many thanks to all Patt
  4. Patt
    Floor Strengh
    My 2B finally passed the IVA this week at the newcastle test centre. The two testers (Colin and Kevin) were friendly, willing to listen and full of advice on how to solve particular fails in in order to get a pass, for example the floor strengthening idea as previously mentioned for easily solving the inner seat belt and rear seat mounting issue with regard to 2B’s. Docs now sent off for registration- hopefully won’t be long until I am taking in the crisp winter air on the wonderful country back roads we have up here in Northumberland seasons greetings to all Patt
  5. Patt
    Floor Strengh
    Hi Steve- I would do this no problem - but haven’t mastered the art of attaching images yet, sad I know. If you want to pm your email address, I can do it that way. Patt
  6. Patt
    Floor Strengh
    I have been in exactly the same situation as you - been building my 2B since 2003 I’m ashamed to say, however, most of the build was done in the first two years, and I only really got stuck into getting it finished over the last summer when I retired . I was really dreading the test as I had no photographic evidence of the build, however, I took it for the test in September, it failed but was pleasantly surprised at the small amount of work I needed to do to hopefully get a pass. It failed on - not enough brake pipe clips, no rubber grommets in the rear brake back plates, petrol pipe not marked as appropriate, exhaust needed protective edging etc etc. So getting to your question, One of the fails was in relation to the inner seat belt mounts needing to have a path back to the main chassis- I already had two pieces of 3mm angle running the width of the car, one above the floor and one beneath, bolted through the floor and both inner seat belt mounts also bolted through both angles. The tester wanted the upper angle welded to the chassis at each side as this would provide the strength path back to the chassis. This I did, plus I had the angle beneath the floor also welded to the chassis- I took pics of this being done as the upper angle ends are hard to see with the seats in. I did contact Kit spares but could not see how the floor strengthening panel would provide exactly what the tester was insisting on. Also on the way to the test the master cylinder decided to pack up - so he couldn’t test them properly. Fitted a new M/cyclinder and took the car back for retest last month and the tester was very satisfied with what I had done Re the floor strength and inner seat belt mounting. He also passed all the other bits and bobs. The brakes was another story, it failed on pedal travel and low performance on the rears. I rebuilt all the brakes with new parts in the early days of the build and thought these would be fine - not so. After so much time I should have really recommissioned the brakes at least, an expensive oversight as brakes mean a retest fee. I have stripped them all down, cleaned and lubricated with high melting point grease. Just need to get them bled now to get a firm pedal. I’m a bit ashamed as belt and braces stuff. Sorry this is a bit of an essay - just wanted to get across to you and others that getting the old 2B through the IVA is not the total nightmare some would have you believe. Patt
  7. Patt
    Brakes
    Thanks A/Z - I will fashion a gasket - and no problem Re the previous info, all food for thought.
  8. Patt
    Brakes
    Hi all - received a replacement master cylinder today from Brakes International ie BMC4052, fits servo perfectly and only needs brake pipes to be bent slightly to fit different outlets. This is not a problem as I fitted then originally with plenty of spare. This looks like a good replacement for the original one ie K0236 311809. The new M/c has come without a seal to fit between it and the servo, the seal on the old one is defunct- does this joint need to be airtight for the servo to work? If so I’m sure I can get one or indeed make something up Stuart
  9. Patt
    Brakes
    It’s a three outlet system - could you explain in a bit more detail how you mounted it remotely Thanks
  10. Patt
    Brakes
    Brake Parts is one of the companies I have spoken to and the only company I have found which lists the correct M/C which is the BMC4729 and as the web page indicates - is out of stock. I contacted them and they couldn’t say when they would get more, if ever! However, your post has prompted me to look at BMC4052 on their page, which is the same manufacturer and pipe entries are only slightly different. I will contact them and enquire if mountings are compatible - if so I will go for this one. Thanks to everyone- I think we may have a solution here Stuart
  11. Patt
    Brakes
    The braking system is totally stock 1989 Sierra 2ltr, discs front, drums to rear and stock servo, all taken from the same donor car. Have tried to attach images but they are being rejected because of size. Stuart
  12. Patt
    Brakes
    Yes I’ve heard the KA one is an option but it seems it’s not a straight swap - I was hoping to get a retest asap. In my many conversations with numerous motor factors and ford specialists, one guy told me that there had been 17 different m/c’s fitted to sierras over the years. I’m sure that amongst all of them there will be one which will do the job, it’s knowing which one to go for. The m/c ‘ that kit spares is different from mine. Stuart
  13. Patt
    Brakes
    Hi dan - thanks for the reply. Bled and better bled the system. It took quite some work to get a pedal, which may also be a sign of a failing m/c The kit was bought in 2003 and was put together by 2005 and then left untouched untilI I retired some months ago. All the brake slave cylinders were renewed but the m/cylinder was never touched- the car has stood for 13yrs! Yes I looked at the escort one but it looks totally different to mine which is much longer. However, if it fits the servo etc Im ok to adapt the brake pipes to fit. Im tempted to go for this as I am pretty stuck at the moment Stuart
  14. Patt
    Brakes
    Hi - as indicated on another post I have recently had my 2B through the IVA and it failed on a number of very minor stuff eg needed more brake pipe clips, covers for electrical terminals, coil needed a weather proof cover etc However on the way to the test station the brake pedal went virtually to the floor, it could be pumped and slightly got better but would go to floor again. Obviously this was one of the fail items, I was very surprised the tester let me drive it back home! As there was no sign of a leak and the level of brake fluid in the reservoir had not dropped at all I suspect the problem lay in the master cylinder. The master cylinder fitted is ford one part number K0236 311809. Here lies my problem as these appear to be unobtainable- I have searched the internet without success, I would rather fit a new item, however, would consider a overhaul kit to get though the IVA but these seem unobtainable also. Can anyone advise of another M/cylinder that will fit without a major rebuild, I seen the posts about fitting KA M/Cs but it looks like a fair amount of work to convert. Any help would be appreciated Stuart
  15. You are the man longboarder, did as you suggested with my spare warning light- bingo! Working as it should. Tried a negative feed to the h/beam warning light, nothing, I assume that thr ‘bright six’ unit has a common earth as all the other warning lights work fine. I have wired up the spare and mounted on the dash, now all good. Can’t tell how immensely grateful I am for you help with this, many thanks Stuart
