Mike Fahey
Everything posted by Mike Fahey
  1. Hi Richy,
    Having real trouble interpreting the wiring up of Motorcraft IGN module for a  1983 2.0 Pinto SOHC.
    This is from scratch, no existing loom, with the Bosch 3 wire inductive dizzy. Orange and violet leads plus black earth as per  pic attached.
    I found your reply to a post on this issue with helpful options on wiring diagram (attached) Could you please confirm that the diagram is as viewed from above with connections going from 1. on the left with the Brown lead to battery Neg. Across to 6  on the right with the two wires from the dizzy, black and red  at no 5 and green and yellow at no 6. Do you know which please is the orange and which is the Violet at 5 & 6?
     Having trawled the internet for the correct wiring up of this module, there is a lot of conflicting advice. As yours seems to be the most helpful found to date, I hope you do not mind me asking for your assistance in this way.
    Great site by the way!
    Many thanks
    Mike
  2. IGNITION MODULE HELP REQUIRED The very helpful post above with the Bosch 3 lead dizzy and Ford Motorcraft Ign Module is very helpful. I have been trying to find a definitive diagram of the module wiring for some time and there is a lot of confusion over this. So Question is: looking at the module from above and at the front connection side with 1 being on the left to 6 on the right. The general advice is that the Ford Brown wire goes to earth and is No 6 eg. on the right. The diagram shows the brown lead on the left at No 1. This ties in with other information I found that the diagram is effectively upside down! As so many guys appear to have had or are having the same problem, head scratching over which is the correct way toi wire up this particular Module - Let us say from scratch, not engaging with an existing loom. I would be garteful for clarification on the diagram as to whether the order of wiring is with Brown at 1 or 6. Sorry for the pedantry in this post but really looking for the correct answer rather than fry the module. Thanks in advance Mike 1983 2.0 SOHC PINTO
