Handyandy
Everything posted by Handyandy
  1. Are there any plans for meets around the bristol or weston super mare area?
  2. Hi Chris I have just finished the refurb on an s7 with a duratec (just a zetec with VVT) using the trigger wheels ecu and the ford edis unit (module) you refer to and it worked first time and really well if you have questions then please let me know, the attached file is for edis 4, i have a full wiring diagram for the microsquirt on zetec if you want that just give me a shout. Cheers Andy
  3. Thanks again tractor, the car is running much better every time i adjust the maps, and essentially i just want it to run ok until i finish all the shakedown work then ill try and find a local dyno tuning shop and get them to set it right.
  4. Thanks guys much appreciated, that has made a nice difference I just need to fine tune but it's much better cheers.
  5. Great thanks tractor what's the Facebook page I need to head over to?
  6. Hello all My first post so please forgive me if this has been discussed before, I'm looking for some help with my new build,I've just finished a year long restoration of my s7, it passed it's mot for the first time in over 10 years. I'm running a duratec on standard injectors and a microsquirt ecu, but I'm struggling to find a standard ignition timing map, is anyone on here running a duratec, I'm keen to see an advance table for a standard set up. I'm experiencing some hesitation when cruising and I'd like to eliminate ignition advance as being the issue. Any help would be greatly appreciated. Cheers Andy
