max
Everything posted by max
  1. max
    type 9 sierra
    Thanks will check
  2. max
    type 9 sierra
    hi anyone know a gearbox specialist sometimes notice mine jumps out of 3rd and 5th gear would like to get it repaired in the winter
  3. max
    oil cooler
    rad sitting upright, i bought the car in bits with engine and gearbox out
  4. max
    oil cooler
    I removed the thermostat when I put the engine back in . It's just like lam not getting a good amount of air flow
  5. max
    oil cooler
    same as mine but i have removed the thermostat, i still must have a air lock somewhere
  6. max
    oil cooler
    do any of you guys run with a a oil cooler on 2L pinto engines to help keep temp down ?
  7. could not take live feed from dip headlights
  8. i would set it at zero most of the old cars was set at this
  9. max
    fan size
    i have a 12" electric fan fitted drawing air though the rad do you think this is the the right size ref my overheating problem or should i have fitted a 14" one ? ref my post in bigday
  10. max
    short sump
    short sump for 2L pinto would prefer steel one
  11. thats the way i have done mine with s/steel dome bolts
  12. max
    badge
    yes i have had a great deal of help and kind offers thanks to richy ( seats) and tony (badge) was well worth the joining fee looking forward to meeting some of you, fingers crossed looking at getting on the road end of month
  13. yes sell them too me
  14. max
    badge
    thank you tony message sent
  15. max
    badge
    anyone got a robin hood badge for sale the one that goes on the nose cone tried gbs but out of stock
  16. hi has anyone got a stick on front number plate if so any problems eg mot/police ect would like to put one on the nose cone like the old e type had on top, not at the bottom of cone
  17. max
    viscous fan
    yes have done this
  18. max
    vented
    the only one i can see is vent thats in the filler neck think mine is robin hood tank s/steel it just goes from filler neck to bottom of the car underneath
  19. max
    vented
    hi how have you vented your fuel tank filler pipe, mine is the std sierra plastic neck into tank and has a small pipe coming off the side near the top and just vented out the bottom off the car is this the right way ? would like to fit one way valve as to let tank vent but stop petrol leaking out in case of a accident
  20. hi we might be interested as well hopefully will have the car finished and on the road in the next 2/3 weeks as only in next county
  21. max
    Starter Motor
    hi take it to a auto electrician they should be able to rebuild it
  22. max
    viscous fan
    hi dan thanks ,think i will go with your advise
  23. max
    viscous fan
    is it best to remove engine fan and fit electric ? is this enough ? or would you fit a additional electric fan and use both
