rory Cosgrove
RHOCaR Member-
24 -
Everything posted by rory Cosgrove
Hi All Sorry if this has been asked before but couldn't find anything directly related. I've had the head and block of my pinto skimmed and are putting the head back on, it has a KC FR33 camshaft and an adjustable pulley on the front. There doesn't seem to be any marks to line the pulley up with for TDC, does anyone know how to line this up with the adjustable pulley and shaft stated, really don't want to wreck the new pistons etc by getting it wrong. Many thanks Rory
Hi thank you for the reply, they look very similar however the current ones have a small solid bar that slots into the engine arm and non of the new ones have it. Is this something they may have done away with ?
Hi All When removing my engine one of the rubber feet pictured that was connected to the engine arms broke. I want to replace the pair but can seem to find the same set online. Anyone know where to source these ? Many thanks Rory
Hi all I've removed my engine from my car and stripped it down ready for new pistons and a rebuild. I'm struggling with removing the outer pulley on the crankshaft. I've used pulleys, heated it and soaked in oil all to no success, in doing so ive now snapped the outer of pulley off and was looking for suggestions on how to remove the rest ? Has anyone manged this before Many thanks Rory
I've been looking g to get my hands on a build mannual for the engine I've taken out I've found the code etched into the flat plate behind the alternator. This reads LP16995- I belive this means it's a 1990 engine and was told it's from a sierra- would this be the mannual to buy ?
Hi there yes it was relatively easy in the end, I removed as many things of the block as possible to give me abit more room, then the engine came away from the Bell housing. All the bolts were accessible with a socket and spanner from above making it quite simple to undo. I then left the bellhosuing/geatbox in supported with a stand. Let me know if you want to onow anything else and I'll try my best to help I'm about to try and sart an engine rebuild as the piston rings have shattred.
Hi, I've stripped the engine components down and are wanting to lift the engine out but there not eyelets to lift from, I've ordered a set and attched the photo does anyone know were they bolt onto ? Many thanks Rory
Hi Ian Thank you for your help, I think I'm going try disconnecting the engine from the Bell housing with this supported by the jack and then slide the engine forward once all other connections are removed. Rory
Hi I'm looking at taking the engine out of my S3A monocoque, the gearbox and propshaft connection look to be boxed in completely, I'm woundering if anyone had managed to remove the engine by disconnecting it from the Bell housing and sliding it forward, its a pinto engine and a type 9 gearbox. As far as I can tell to remove the gearbox it will involve cutting welds on the stainless steel plate around it. Anyhelp much appreciated.
It starts cold and runs for a few minutes before splitting and then misfiring and stalling. Does this sound more like choke or a coil ? Reagrds Rory
Hi got the 2l pint engine on a webber 28/32 carb. It's got the original mannual ignition from the key on it.
Hi Whilst driving the other day my car started misfiring and cut out I was then unable to get it start for some time and when It did there was big smoke plume it ran for little n cut out again. Any ideas what may cause this ? Many thanks rory
Just currentley have the original mechanical pump attched to the engine, is it worth updating this to an electric on or replacing with a like for like ?
Hi yes thankyou the clutch cable was slack so tighened this and clutch is now running. Next problem as soon as it gets warm it splatters and pulls air bubbles up the fuel line and stalls any ideas ? Many thanks rory
Im not sure on the setup i belive it maybe a superspec as it manily stainless steel bodywork folded to make a chasis, however is first registred in 98. Ive attched some photos of the top of the pedal bos and the connection to clutch plate if these are anyhelp. Im located in Teesside area if there is someone willing to take a look let me know! Cheers rory
Hi i recently snapped my clutch cable, ive put a new one and can go through the gears fine whith the engine off but not its whilst running, is the next job a new clutch ? Any help would be great cheers rory
Clutch pedal gone slack
rory Cosgrove replied to rory Cosgrove's topic in Maintenance & Modifications
Hi what would tell me if it was superspec? -
Hi yes you were correct snapped clutch cable so just looking for a replacement. Any recommendations ? Thank you for posting the identification doc ill try work out which it is. Many thanks for the help -
Hi i was told on buying it was a robin hood 2b but never been 100% sure The cable looked okay but i didn't notice a quadrant in the pedal box when i removed the top in the engine bay ? I'll take some photos tomorrow when i get the car home and put them on here. -
Hi When i pressed the clutch in today there was a crunch followed by the pedal becoming very slack and unusabale. Also yesterday the car wouldnt select revers but all gears were working fine today when i first went out. Luckily i hadn't started the engine but was woudering if anyone knew what may have caused this ?
Hi I recently broke the rear suspension, I've got a new set of 2.25 id, coil over AVO shockers. My question is what lb of spring will these need or whats recommended? Is there anyway to tell off the old ones ? Any help would be greatly appreciated.
Hi I have snapped the rear coil over shock absorbers on the car, the ones that I have broken are a AVO 130 090 I can't seem to find a replacement part and was woundering if anyone would be able to help me out with advice on an alternative replacement. Thank you in advance for any help . Rory
