Darren Knowles
Everything posted by Darren Knowles
  1. Hi all Anyone interested theres a free to enter car show at wilburton near ely cambs Saturday 13th july suit members in Cambridgeshire areas email to enter is : saeventsuk@outlook.com
  2. I had s granada 2.0 years ago used to smoke like a chimney if too much oil in it
  3. Hi Dave thanks mate but I found one on marketplace yesterday so sorted now cheers
  4. Darren Knowles
    Sabelt
    Evening all has anyone got a sabelt seat belt in black with yellow labels as fitted as standard in the 3B one of mine is frayed on drivers side where it bolts to the tunnel cheers Darren
  5. Try fast road cars , very helpful
  6. Hi Alan will try to do this one had a really busy summer!
  7. Try ignition coil may be failing when hot ?
  8. Try fast road cars he stocks everything very knowledgeable
  9. Thats the answer i was hoping! thankyou
  10. Evening all on the 2b do the seat belt mounting bolts have captive nuts on the gear tunnel as i need to change mine thanks Darren
  11. Hi Derek are we booked in with the 9 for lunch there are 2 of us was ages ago and couldn’t find where we said book us in cheers Darren
  12. Evening i had leak on my master cylinder ended up replacing in end as I couldn’t get it to seal kit spares do a sierra replacement off shelf hope you get sorted dazza
  13. What a bummer alan , always something mine had the alternator bracket snap in half last week, at least they keep us on our toes !
  14. All sorted got new master cylinder from kit spares brakes are much better now next upgrade will be gaz shocks
  15. Steve correct it is defo 22mm im trying kit spares today as they stock a replacement so fingers crossed thanks for reply
  16. Hi all have master cylinder leaking tried reseal still leaking so looking at new one as only £50 ! Mine is 20mm bore looking from driver seat has outlet to left which does rears and two on end that does front, I believe its a mk 1 sierra one most on ebay have outlet on right this is ok as pipes are long enough question is will this still fit servo im assuming the later ones were 22 mm bore , im sure someone on here will know if there interchangeable! cheers for any help darren
  17. Excellent thanks for the info haven’t bought the kit yet wanted to do homework first will be replacing all existing coilovers with the gaz shocks also unless there are any others that are recommended
  18. Hi when setting the top ball joint do you set the wheels upright or angle in slightly , mine at mo with standard wishbones are pretty upright? cheers Darren
  19. Afternoon all all booked and paid will hopefully see a few of you there happy new year cheers Darren
  20. Hi all im looking at fitting this to mine what are the gains, are they noticeable cheers Darren
  21. I cut these off my beemer tonight, now all the tyres are flat
  22. Try fast road cars ltd , i had complete manifold and carb he builds them up so i guess he would sell linkage , you will probably need a cortina throttle cable and retaining clip as well to suit
