gdc
Everything posted by gdc
  1. gdc
    Lightweight
    chears nigel i will look to purchace tomorrow regards graham
  2. gdc
    Lightweight
    hi all i have taken the view that 2 have passed sva. therfore the basic concept is sound,i have embarked on a a mission to streagthen the car to hopefully achieve sva standard ,there is a meeting of some of the lightweight builders and the owner of the only sva passed lightweight out side rhsc next sat the 28 , to try to thrash out the issues,hopefully simon can get here , if rs still has any time to view the site pherhaps his design prowesscould be harnessed to help resolve the problem,.gbsc take the view that 2 have passed so no problem their input would also be valued,it also wouldnt hurt their image or credibility. i am happy for mine to be the test bed for ideas not cos i want mine finnished first! but if it goes wrong then i am in a position to scrap mine and move on to another project others are not in that position , as most of you are aware these cars are riveted and bonded together, drilling out the rivvets no prob breaking the bond without damaging the panals a different animal altogether, so the alterations as far as poss have to be done to a completed tub sympathetically. and with a lot of brain hurt!!!!!!!! ohh by the way 5mm alloy ant cheap, by the way i was told by a mate today that a yellow lightweight traveling through france smashed its sump on some bricks,as read in a car mag.???can only be the rhsc car i think? babble finnished regards graham
  3. gdc
    Sliding Pillar
    thanks for the info dan once i have hopefully sorted the lightweight out i may well look at changing over to wishbones. but i have my hands full at the moment. best regards graham
  4. gdc
    Wednesday Titter
    i erd a joke the other day thats where northern people come from
  5. gdc
    Sliding Pillar
    hi dan did you upgrade the pillock or change the car ? i am trying to find an upgrade that dosnt need a nasa degree to fit. just sva d and the long winter is comming , so time is not a prob regards graham
  6. hi i have used an adjustable colum i think from a 4x4 siera , just drops out of the way. regards graham
  7. gdc
    Anti Theft Device
    hi dave you might want to add a battery isolator regards graham
  8. gdc
    Anti Theft Device
    donnt be creul ikant spell neither regards graham
  9. gdc
    Cooling
    hi tim looks the same principal as my lightweight except i have a pressure relief on the header tank been run static for in excess of half an hour with no probs. i am a plumber but would bow to any more experiansce regards graham
  10. hi danny i have a plastic tank but fully supported on 20mm angle iron as a base frame the material is only 4mm thick could you not accomodate a 4mm height difference.i think chris's comments spot on my sva man spent a lot of time checking the tank and its supports regards graham ps chris have you got my cheque yet
  11. gdc
    Sliding Pillar
    hi recently sva passed 2b pillar waiting for regestration lots of sliding pillar 2b s have been changed to wish bone how do the pillar types handle? are there distinct advantages to wish bone instalation? or do you learn to drive the pillar type from experiance i used to race hot rods and the adjustability of the shocks was an advantage, however is this nessary seems to me if i corner hard one of the front wheels is going to become airbourns as there is no means for the wheel to drop below the bottom mounting, my fear is going straight on at corners or trying to steer with the right foot not a good plan with an 1800 pinto. regards graham
  12. gdc
    Sva Pass
    hi chippy well done i am still waiting for my docs to come back from dvla so i can get my plates ,the longest week of my life , any way gives you time to get rid of the sva crap, not that i would condone that !!!!!! well done enjoy you are a quiet one . regards graham
  13. gdc
    Fuel Tank Caps
    hi marcus that easy weld ant so easy its a bit like soldier it flops!!!!!!!!! and wont stick to small areas. ie right angle seams ,its difficult to complete a circle as there is a fine line between making it work and it falling on the floor . its ok it seems for small areas or where you dont have to join the point at which you started, cos then you just melt of the first part you started with . regards graham
  14. hi keith thanks for the reply it will be great to see all the owners pm me for address detailes 5 heads for the head to head !!!!!!!!!!!!!!! + any turning up on the day. iwont holdmy breath for rhsc to pm me for details . can i ask any !!!!!!!!!!! interested parties to pm me for detailes it is happening!!!!!!!!!!! if you as a lightweight owner are holding back waiting to see what happens ,DONT!!!!!!!!! regester interest now there are more than 5 with an in built design prob, either you dont know of the prob? think you can build your way out of the prob. or will alter your chassis based on info recieved. be part of the resolution to the issue.your input is valued. open your gobs !!!!!!!!!! regards graham
  15. gdc
    Fuel Tank Caps
    hi marcus i ant sure for my 2b i fitted a locking type with restricter, it came wilh the neckfor the tank .i had to create a split flange to go in the tank with nuts welded to it so as to connect the neck to the tank bit fiddly especially with an almost full tank of petrol .i was ill for days . dosent answer your question but as i was unsure ispent the extra regards graham
  16. gdc
    Sva Pass
    hi regestered the 2b today should have logbook back end of week then get plates made up . never driven one, never even been in one . how will it drive ???????????????? will i like it ?????????? hope so, regards graham
  17. hi ian has confirmed head to head 4 heads now any more regards graham
  18. hi marcus has confirmed fo head to head regards graham 3 heads now any more ?????
  19. hi rich many thanks for the encoragment from yourself and others as regards rhsc richard and his team know of the issue ,richard posted in the last 2 days and should be aware of the efforts being made to put this meet in place ,i am not prepaired to ask for rhsc to attend as the new rhsc and the old rhsc are seperate entities ? however should a member of their team wish to attend they would be more than welcome, the input would be valued and appreciated . ps not holding my breath . regards graham
  20. ok colin from norfolk is in how many more as i said earlier one will start it we are having a head to head all be it only 2 heads at the moment regards graham
  21. many thanks barry the more debate the better however these problems have to be seen. in the flesh regards graham
  22. hi sue thanks just trying to help sort this mess out regards graham
  23. hi to all interested parties i have posted before to gain the support for a meeting to discus the lightweight chassis problem . to date i have recieved 6 pos replys , as they would, they come from all parts of the country and support and advice from abbroad.the rhocar forum is an excelent way for us to debate the problem ,however unless the concirned parties can comunicate and debate the issue on a one to one basis with a project in front of them.then debate on line is all we are going to get. the advice from more experianced builders is essencial and invited however just by posting photos of a particular area will not give a full picture of the lightweights full problem ,the sva faults have been highlighted in passed posts,but as i see it lacking a chassis in a monocouqe design should not be one of them. i am in a fortunate position in that if the mods to the lightweight are unsucsfull then i am in a financial position to strip mine and transfer usable parts to another project, others are not !it would be a tragic waste of time and effort on all our parts to have to do so, i have sujested the venue as dunstable it is close to being the centre of the country the workshop is large enough to accomodate the car tub was complete thus allowing a full view of the problem to allow all builders to acces the issue either just started or further through the build proces we will get no further help from rhsc or gbs except 2 have passed sva many of us have seen the one that failed sva i do not wish to be in any way un kind but even if this car? had a chassis made of steel girders it would hav e failed on build quality (my opinion) we can accomodate if rqd (no i am not in to wife swapping) i have started to undertake mods i do not know if these are enough to satisfy mr sva or not . i have just sva passed a 2b a different beast i know . to all rhocar we need help !any one with in put is welcome the date i propose is28/ 29 october please e mail me at gdcheating@hotmail.co.uk anyone with an interest is welcome if only one person shows interest it will go ahead and before any of the smart as es among you ask no i am not a lonely prat . this is something that i feel has to go ahead to those experianced builders out there stick your oar in regards graham
  24. hi scot thanks fothe info my answers to questions may appear short and tothe point . this is because i type so slow and the thred would have ended before icould make apoint ,this is the main reason to have this meeting regards graham
