986 -
14
Posts posted by Thrashed
I would be up for C&M.
Could the TPS be faulty?
Wow. Now you have had a practise mine is going to be amazing!!
Driving lessons so I can drive like Colin McRea.
44 minutes ago, blue said:
Hi that’s the same setup I’m thinking of using
what mods did you have to make pls as mine is an early chassis
does the NC 6speed fit or just the 5 pls.
Yes, the 6 speed will fit the Duratec, based on my research, but fitting it into the chassis is a whole different issue!
The casing for a 6 speed box is much bigger than a 5 speed. The 5 speed bellhousing catches the tunnel uprights and the reverse detent house clashes with an upright rail. The gearbox mounts are all in the wrong place. The type 9 mount it too high and too far forward and you then have to chop of some of the gearbox webbing to fit in the tunnel.
In short I moved 2 uprights, added an extra upright and remade the gearbox mounting plate. The MX5 NC bellhousing is just too big for the original tunnel.
Feel free to PM me and I will happy give my phone number to chat it though, I have a `diary' I have been keeping which is kind of a build blog, I would be happy to share.
Agree, I tried that originally. I tried both the NA and a NB gearbox. They do not fit, and would need an adapter plate and large amount of work. I have a 5 speed NB gearbox in the shed if anyone wants a cheap gearbox!! I took all my original advise from GBS, but it really didn't pan out as they explained it might.
Ok. I am using a st150 engine and used a mk3 mx5 NC gearbox. I also do have a very early zero chassis (3rd chassis they ever made).
Might be differences in newer chassis but I am not aware of a ns 5 speed.
I have pictures to prove it didn’t originally fit in my chassis. Does now .
Not tried the 6 speed as the measurements said it is bigger than a 5 speed but the 5 speed box needs modifications ( webbing chopped off) and so does a couple of chassis support bars.
35 minutes ago, Rockabilly Boy said:
Hi Yep Danst did my original manifold for the Zetec lump. I was loathe to call them as I'm not buying anything and feel a bit cheeky sapping their knowledge for no benefit to their business!
I'm only after a starting point really for the pilots in particular - as they can be dog rough on the standards. What size have you got on the pinto? (the Fiat is only an 8 valver so probably quite similar to the pinto in fuelling)
My experience with Danst has always been very positive. He is always happy to help. Might be worth a post on his Facebook page.
Probably means your car is already awesome!!
One of the few times ever i tried to order online today and got a no delivery option available message so couldn’t order!
Thanks all. I am luck enough that i dont have an holes pre drilled. This means i get a choice. Having done some mock up i think i will be copying Dan and go with the passenger side park.
It seems to sweep a bigger area of the drivers side and higher on the screen too. Having a blank canvass means i can fit the screen and then tweek the wipers to fit.
What could possibly go wrong!!
44 minutes ago, brumster said:
This layout gives way better clearing of screen for the driver, it gets up nicely on the right-hand edge (as the driver sees). I spent a long time carefully trialling and positioning the blades to work out where the holes would go (my car wasn't pre-drilled, thankfully). I was so thankful of these at the Wales weekend the other year - they really made the whole weekend so more "pleasure" than "pain" :). Standard Defender wiper motor in terms of sweep angle/gear.
Cheers Dan. Gives me something to think about! Will have a play around this weekend. Always good to get another perspective.
Thanks
15 hours ago, brumster said:
Thanks Dan. Confirms a lot of the measurements. Just out of curiousity, why park on the passenger side? Most I have seen park on the driver's side?
Steve
8 hours ago, knights_templar said:
Hi
Does the scuttle have the pre cut holes for the screen brackets?
If So
https://www.dropbox.com/s/wctjey9hf0d7guj/2013-02-06 15.44.52.jpg?dl=0
Get kit
https://www.dropbox.com/s/30ar21imqpzqxyc/EXTWPS2_IMG_2681.jpg?dl=0
Fit kit
https://www.dropbox.com/s/45gsnuy1ev66d9e/IMG_5849.JPG?dl=0
Sorry, still looking for measurement to cut tube, think they are in the manual somewhere
Mod wiper arms
https://www.dropbox.com/s/dl8pm4g7rv757q7/wiper arm build.docx?dl=0
Shout if you need anything else
Regards
Thanks KT, already been given the 1st picture with the measurements. Good and useful info. Must admit I have been looking at the Car Builder kit which looks the same and has options of sweep available, plus is about £50 cheaper!
Thanks again
Hi all. Hope everyone is safe and well.
I need some help from Zero owners. I have the zero standard chassis, so if anyone can help, that would be great, to make sure I get the correct parts and mount them roughly in the right area.
I have finally given in and am moving from the aero screen to a full windscreen.
I am measuring up for wipers and need some measurements as follows:
1 - Distance from screen to wiper spindle hole (gap between screen and wiper spindles)
2 - Wiper spindle hole centre to car centre line
3 - Wiper arm length
4 - Wiper blade length
Many Thanks
Steve
Thanks for organising last night Richy. Another great turn out with over 30 people.
Can you add Bob and Di too please.
Dee, Paige and myself will be there.
Screen is now sold.
Not 100% sure bike carbs will help with fuel economy. My old pinto with the ZX6R carbs would average about 23mpg on a steady run, but had it as low as 17 on a push!
I am hoping fuel injection helps going forward.
You two are either very brave or very crazy? Hope you had fun!
Happy New year to everyone. I hope 2020 bring many dry driving days.
I bought this complete screen which was taken off a 2b.
It is the complete screen with side supports. The side supports are already bent to the scuttle shape so should be a drop on item.
I bought it as I was hoping it would fit a standard zero scuttle but is doesn’t. The screen looks as new and the fit and finish is very good. The side supports will need painting as this is bare steel at present.
Looking to get £100 for it which is what I paid for it.
Postage will be an issue due to size, shape and fragile glass. I do travel a fair bit with my job and am regularly in Telford/ Shropshire, Swindon and towards the East Midlands I am happy to meet up within reason.
https://drive.google.com/drive/folders/1j8BX7dnSMddlugWU7HnSj0R454q4LtUm
any question please ask.
13 hours ago, richyb66 said:
Yes, good ride out but C&M need got get their 5hit together on the food and drink orders.
Luckily Jackie took no prisoners when we paid the bill and got the drinks knocked off the bill which Thrashed kindly paid.
Thanks mate, I'm sure I'll find a way to pay you back!!
Yeah. Food service was poor but you are more than welcome. I will definitely get you back. I got a screen, roof and doors that need doing!! Catch up soon
30 minutes ago, Matt brown said:
What have you got left to do?
Far too much. Tidy up the wiring. Fit the windscreen and wipers plus wire them in. Then bolt all the panels on, refit the seats and interior then hand it over to Richy for doors and Surrey top.
Warks / Worcs / West Mids Monthly Meet August/September 2020
in Events
Hi all. Weather is looking reasonable for Tuesday. Who is up for a trip to Caffeine and Machine? Be nice to catch up with you all. I am planning on getting there for 6:30-7pm. An yes the Zero is still off the road so will be in the tintop!
