speedtripledan
Posts posted by speedtripledan
  1. when my type 9 destroyed its lay shaft i rebuilt mine with heavy duty lay gear bearings and changed the gearing to v6 ratios i also sourced some heavy duty synchros for it. my 242bhp 260ft lb supercharged zetec didnt break the new box ! i also fitted the a quaife ATB which is great bit of kit transformed the car..
    With v6 ratios and a 3.54 diff the car would pull 65mph in 2nd gear.
    https://www.bearingkits.co.uk/FORD-GEARBOX-PARTS/FORD-TYPE-9-GEARBOX-PARTS/C1-10-1-0.htm best place i found for type 9 parts
  2. Just a heads up, when buying these cheap policy's from the above and probably others, if you cancel the policy because let's say you sold your car they do not refund a single penny ! My policy was approx 2months old and her words were " there is no refund due after cancellation fees blah blah ". robbing bleeps ! I won't be using said company again for anything.... So beware peeps
  3. It took me 6yrs but I've sold the kit car, i.m done with kit cars now, after 12yrs of kit car moding and owning I've got bored of it all.... Bought a big Merc instead,  1car does it all tows the van, goes like *bleep* of a stick. Comfortable and SAFE.
    Have fun everybody
  4. I always dreamed of having / building a really fast car, now I’ve done it i hardly use it. I’ve done more mile’s on my mountain bike in the last 4months than I’ve done in the car all year ! So it’s time to let someone else enjoy it. I bought this car 5yrs ago as a bog standard stylus with 1800miles on and have spent 5yrs and 15k getting it to what it is today. 11000miles Spec is massive.
    zetec rebuilt with new main bearings, big end bearings and new oil pump. Bespoke mp62 supercharger conversion built by red7 autoengineering Ripley. Incorporating nissin gtir plenum, rx8 450cc injectors, custom inlet manifold. Twin 70mm throttle bodies. 60a denso alternator, twin belt drive one for the alternator one for the charger, electric water pump.
    Canems ECU Dyno.d by Dave at canems with dual maps, Map 1 is 243bhp and 256ftlb of torque. Map 2 is 130bhp great in the rain or when you have cold tyres. Flick of a switch while driving and it will go one to the other.
    Custom repackable stainless exhaust made by Martin Keenan (mk fame) Helix 4paddle hd clutch to handle the torque
    Raceline flywheel and sump
    Oddesey gel battery.
    Push button or key start.
    V6 type 9 rebuilt with all new bearings, Hd layshaft bearings HD synchro rings.
    Retro ford hydraulic clutch.
    Davis Craig ewp water pump and digital control.
    Retro ford water rail with triple core coolex alloy rad and intercooler.
    Mocol Remote oil filter and thermostatic oil take off and cooler. Procomp suspension all round
    Dotz mugello alloys with Toyo r1r tyres Willwood Midilite front calipers on 285mm vented drilled discs
    Rally design rear disc brake conversion 240mm discs
    English axle with rare 3.54 genuine ford cwp with quaife ATB diff
    Custom stainless 8.7gal fuel tank facet silvertop low pressure pump into swirl pot and sytec hp pump.
    ETB cobra white face gauges Mountney steering wheel
    Bespoke alloy gear stick knob and matching stalk ends.
    Led headlights
    Full weather gear
    Obp billet alloy pedals with willwood cylinders
    Cobra seats colour coded to car.
    mot till June.
    I've probably missed stuff off the list Have receipts for best part 20k This is a very quick car, not for the faint hearted! Good for 60 in the low 4,s. You can pop to the shops or blast it round a track, eat up the b roads, cruise up the motorway. Irritate bikers with its performance. It really is a sorted all round car. £10000 ovno
    Can email photos if interested
    Or will swap for hot hatch tintop ie focus st, golf/ Scirocco GTi etc
  5. My car has a 2.0l swirl pot in the engine bay, fed from the rear via a facet silvertop low pressure pump, I did track days in the hot summer we just had with no issues what so ever on the fuel system.the oil overhead and the brakes melted but no fuel heat issues or surging problems. Why is it in the front ? There was no room in the back and the fuel tank wasn't suitable for modification at the time I converted the car to fuel injection. Use a good lp pump and it will be fine, mount the pot away from the exhaust in the air flow if possible and it works great.
