You've got it all. Power, passion, precision, and style. You're sensuous, exotic, and temperamental. Sure, you're expensive and high-maintenance, but you're worth it. cool.gif
Lol, I was some little Mazda thingy.
Hate to think what that said
Usually dislike this sort of horoscope type stuff but this one is really quite good.
(Borrowed from a Sierra forum)
http://www.tomorrowland.us/sportscar/
Me and my better half keep Black Rock hens purely for their free range egg laying abundance
Problem, is the minute you step out of the back door or the garage door they`re straight in.
The one in the picture always hops on to the drivers side lamp and just stares at her reflection,
but today after I nipped out for 20 seconds, she got in and the bonnet was up with the engine running.
Luckily she was away from the wheels and belts but she was dancing on the battery.
Think ill have to get a garage spring door closer.
Decided 3 years ago now to plumb in a wood burner that heats up central heating and water.
Still got the gas for when you just need to heat up water quick etc.
But now our winter gas quarterly is just £15. And the logs come from council tree and ground depots
for free.
Mind you the burner costs aroun a grand and £250 for a log splitter.
But still worth it...........
Think ive found the problem, when stripping the carb I noticed a mixture screw missing on the affected carb.
Seems like it fell out in Yorkshire.
Seems that the stiff ride of a Hood can eventually rattle everything loose.
Now a tour of the bike shops is needed.
What a great feeling, not paying a garage.
Well slowly I am learning the basics of mechanics but I do have a problem with misfiring.
I am getting into the RHOCAR way of thinking and refuse to take it to a garage (well unless I havnt done it by the time summer comes and goes)
Its a pinto ohc 2l with R1 bike carbs and lumention electrics.
I took the car to Bogg Bros and it went like a rocket after. But 2 hours into the drive back it started to backfire like mad.
The engine sounds like its running on 3 cylinders especially when its revved just a bit from idling. I used an inline spark tester
which shows the plugs to be firing well, and the chopper in the dizzy looks fine,
Ive replaced the dizzy, plugs and leads, visually checked the timing at no1 tdc, done a compression test (all cylinders 9.9 and 10 bar) Ive loosened the carbs and squeezed them on to the runners a bit more (this has reduced the backfire) but now there is a strong smell of petrol. Also if I put my hands over the air intakes, no1 doesnt do anything where as the other 3 will slow/stall the engine.
Im about to attempt to check the valve clearances then scarily enough strip the carb.
Do you think Im going down the correct route?
Thanx
Does anyone near Leicester have a spare bracket that the alternator bolts to
on a 205 pinto? Beer tokens issued.
Or are there any products that would fix a slipping thread?
Thanx
Hope this helps
Sure did, it ran fine for about 15 minutes now the old V8 sound is back
and backfiring a lot.
Have to check the spark when i get a minute and possibly the bike carbs as they have a tendency
to come loose at the manifold hoses.
Maybe a dumb thing to do, but have replaced plugs, leads, diz cap, rotor arm
to try curing a misfire, and Im not entirely sure the leads are on correct.
See picture
Was down Norwich for the weekend and went to Snetterton Sunday market.
There was a guy there selling brand new biker helmets for £24.99.
Ideal for aeroscreen users.
Nice n cheap
Yup! It was the starter, well solenoid. But the problem was intermittent. Wasnt till the
3rd time of dismantling and cleaning that I found it.
Got a recon for£45 that looks brand new and all is wel.
So glad it wasnt the flywheel.
On cranking the ignition Ive started to get a horrible grating noise from the starter (either that or a slight delay before cranking) Ive read many previous postings and it seems like it could be the starter gear, or at worse the flywheel.
Just checked the connections and the solenoid end to where all cables go is very loose at the wire end but not the other.
About to strip it all down but would be handy to know if this would be the cause.
