Redspec
790 -
2
Everything posted by Redspec
Just spoke to Artie on the phone, the forecast is for heavy showers and it has just started raining here, so the run is cancelled for today. Artie says he will plan a new date for when the summer arrives. Steve
That sounds like good news, I will be at Washington to leave at 10-00 Steve
Hi Steven, The stud that requires welding is one of the starter motor bolts, it screws into the adaptor plate, but it can not screw through due to the block, hence only a few threads. There is a tube on the gear leaver remote that just sits over the top of a bolt head, I drilled a tapped the tube and bolt head and fitted an M4?? high tensile bolt to stop any movement, but the quick shift may sort this if it comes complete with the remote mount. There have been a few posts about jumping out of gear, and I'm sure someone found the problem, but I can't remember what it was, I don't think it was down to alignment issues, more selector / retaining spring issues. Steve
Typical bloody summer weather, if we still go I will be at washington services northbound at 10am for anyone coming from the south, And then meet up with you at Stannington services NE61 6ED about 10-30??? Steve
+1
Me too
:cray: Would have loved to come but will be in Bolton visiting family Have a good one Steve
North East area meet, tonight, I will be there from about 7.00 pm to have a bite to eat before the tyre kicking starts. Church Mouse Ch-le-st http://www.vintagein...estreet/findus/ Steve
+1 Do you want me to book the sunshine LOL Steve
Got Basic drawings for the dimensions, they may need tweeking to fit as with all things RH. PM your email if you want a copy Steve
- 21 replies
- Ride height
- Rover
- (and 4 more)
Hi Ed, Looking at the pic in post #9 it looks like you have the shorter sump (some superspecs came with an engine for a 420) like all things RH different things were fitted to the same model cars it all depended what they had at the time. The 93mm filter is just shorter than the shorter sump, the filter that came with the kit was 25mm ish longer. In the picture it looks like the front of the sump is lower than the back or is it just the angle of the photo? Is the front engine mount doing it's job. Keeping the bottom of the shockers close to the hub is the recommended way as you could (not will) bend a bottom wishbone, to gain ride height wind up the spring seats. As mower man says a sump guard will take away some of the clearance but when you know you are going to hit something I would rather it be the Guard, and you will never get 3.5 - 4" under the sump on the superspec without the bottom wishbones sitting at a stupid angle. The Zimmer shocks are just not up to the job and when I changed mine after only a few miles they were totally Knackered. Was the sump guard made from tread plate in a photo that was taken with the car held up on fork lifts? Steve
- 21 replies
- Ride height
- Rover
- (and 4 more)
Looking at the picthe filter is the same level as the sump, is the bell housing lower? if so (or the same) you have the short sump. Just been out in my fluffy slippers and my filter is about 85-95mm but is above (just) the level of the sump and they are (just) above the level of the bell housing, If they are all level that is the best you will get without lifting the engine, jacking up the suspension. Time for new front suspension and a sump gaurd Steve
- 21 replies
- Ride height
- Rover
- (and 4 more)
You have a T series engine the K series was only a 1.8 max
- 21 replies
- Ride height
- Rover
- (and 4 more)
Just found the list of filters in that post and it was a reply to another post from you on the same subject, if you realy want a remote filter kit I have one you can have for £45-00 + PP, I bought this before I found shorter filters OR SPEND £5.99 on a new filter
- 21 replies
- Ride height
- Rover
- (and 4 more)
What engine do you have? you say K series then talk about a 420 sump The 420 used a 2.0 T series engine that was used in ithe superspec? If you have a T series engine just fit a shorter filter - no need for remote Steve For details of Filters search posts off the last 2 weeks
- 21 replies
- Ride height
- Rover
- (and 4 more)
When I got my Superspec it had standard tank / sender with ETB gauges and they worked fine, mind you with a 12 Gal? tank you have a bit to play with you don't need it spot on, even a 1/2 full tank is more than most people have to start with.
Listed as 21 hrs, he only has a feed back off -2000, but as a buy it now for 99p it was worth a punt.
Hi paul, you missed a great day, but if shopping is more your thing these days :crazy: rather than hanging out with like minded folk these days, well what more can I say. PM the sizes I should see you Wed at the mouse Steve
Just a big thanks to all that made it a great day, I made it about 17 for lunch BBQ?, Pleased the sunshine that I bought off e-bay turned up as I thought it was just a scam advert. LOL Big thanks to Liz and Margaret for feeding and watering us all day Steve
Can you upload them to photobucket? If so upload them then cut and paste the img link into your post Steve
You have PM, Mike has the details if you have any problems See you soon Steve
Hi Paul Don't forget the measurements for your boot lid, I have found a offcut of carbon fibre effect ABS that should do the job. See you sometime Sat. Steve
Fit a shorter one - look here http://www.rhocar.org/index.php?showtopic=33269&hl= Steve
Long time no see, look forward to it. Steve
