Deano 777
    84
0 Neutral
1 Follower
About Deano 777
  • Rank
    Getting there Builder
  • Birthday 03/03/1976
    2B (2002 model)
    Dean Larkins
    sittingbourne kent
  1. Hi tommy, has the head had any work done to it? Dean.
  2. hi guys, thank you all for your info, i have just read up on this cam, and it is not suitable for me, i am already running a kent FR32 with an adjustable pulley with 45's and a burton power moded dizzy kit on a 205 engine. i am only getting 119BHP @ 6500 RPM and around the same in tourque. i was told by the tuner that the next stage would be to tune the head and the next stage cam. can anyone point me in the right direction? thank you again. Dean.
  3. Hi i have just bid and won on a new Dave Walker Emerald Full Race Cam Phase 5 for a 2.0L pinto. does anyone have any info on this make and model of cam. any info will be good, Many thanks Dean.
  4. before you adjust the suspension, is there not a part of the metal panel that can be cut away from the UJ to stop it hitting?
  5. it could also be because the sierra did not origianally have a V8 under its bonnet, all that extra weight on the front of the vehicle will over load the standard braking system on the front axle. i would recommend that you should fit an upgraded brake kit, also a brake bias valve to stop the back brakes locking on before the fronts. take a look on here, www.rallydesign.co.uk hope this helps regards Dean.
  6. My advise would be, take your time with planing and building the kit. you will have good days and you will also have VERY bad days along the way. But dont give up. take pic of the build at differant stages. good luck. Dean.
  7. Deano 777
    Hello !
    Hi james, and Welcome. driving this type of car is as much fun as you can have with your cloths on!
  8. I have 2.0 pinto with standard gearbox and diff from doner. i have done over 100mph with just a small fly screen and a pair of sunnys on. (With Flys in my teeth)
  9. Due to breaking my leg i can not drive my 2B untill December now. its like having your favourite sweets right infront of you and you cant have any! life is not very fare to me at the moment
  10. Hello graham, the flames are caused by over fueling or ignition timing, my 2b flames from exhaust but my engine is running 2x 45 webbers. a good tune up should sort things out for you. the clutch cable should self adjust, if not push the clutch pedal down then side step your foot off and let the pedal come up fast this will reset the adjuster, hope this helps you. Dean
  11. thanks guys. i will book something up, and will post up my dates, for if anyone anyone wants to join me.
  12. hi mark, it could be cam bearings? you will have to remove the head from the engine to remove the cam shaft, as it comes out towards the rear of the vehicle, the bearings should be pressed out, but if you dont have a press than you can use a soft drift and a hammer, puting them in can be done the same way. hope this helps you, Dean.
  13. A big thank you to andy at B&D engineering. newington Kent. (01795) 843980. for the set up of my twin webber 45's contact him for advise, tune up/ power run, Thanks again, Dean.
  14. Nice job, Well done. i love the style of wheels,
  15. Hi, does anyone have any track days booked at brands this summer? if so what dates and how much does it cost for a session? i would like to get one booked before the winter. Thanks Dean.
