neil stobbart
neil stobbart last won the day on April 21 2011
neil stobbart had the most liked content!
1 Follower
About neil stobbart
  • Birthday 12/21/1969
    2B with own wishbone conversion
    Neil Stobbart
Contact Methods
  • Website URL
    http://
    Bishop Auckland, County Durham
neil stobbart's Achievements
Builder
Builder (2/5)
  1. All, Deciding to sell the car has forced me into having a clear out - various bits and bobs looking for a new home... Type 9 clutch arm & release bearing - stamped with item code 71BB7541KA 165946 - Its 282mm beween the pivot point and the cable ball position - must be of some use to someone - £15 delivered. Black clutch quadrant kit - New - £6 posted. Richbrook polished aluminium handbrake level cover - New - £12 posted. JAMEX alloy pedal covers (curved) & fixings - New - £15 posted. SPARCO Alloy pedal covers (curved)& fixings - New - £17 posted. Machine Mart piston ring compressor - New - £8 posted. Forged steering UJ - 75mm long with 14mm female splined ends - New - £18 posted. Pair Mini wiper box trims, nuts & wedges - Chrome - New - £7 posted. Sierra steering column bearing - New - £3 posted. Battery terminal covers - New - £3 posted. Pair sealed beam units & sidelight bulb holders - Used but in fanstastic condition - £10 posted. Pinto OE style top hose - 32mm connections - New - £15 posted. See photobucket link for photographs... http://photobucket.com/kitparts PM me or call 07805 513781. Cheers, Neil
  2. Robin Hood 2B kitcar. SVA completed August 2008 having spent more hours than I care to imagine on the build. This car has been built to a very high standard with many bespoke parts and extensive powder coating – no expense was spared so it really does need to be seen to fully appreciated. The reason for sale is genuine, I simply am not getting enough use out of it – this is confirmed by the fact that is has covered only 884 miles in three years!! Specification: Engine 2.1litre Pinto. Bottom end based on 205 block with new pistons, Injection con rods and lightened flywheel. Block decked. 10.3:1 compression ratio. Pistons, crank, rods, flywheel and clutch cover all balanced. All new bearings, seals and gaskets. ARP rod fastenings and flywheel bolts. Heavy duty AP clutch. High capacity oil pump. Fully baffled and shortened sump with side wing to retain capacity (no bottoming out or oil surge) 13 row oil cooler and oil stat. Oil breather tank. New alternator. Stage 3 Big valve head with stainless steel flat head, waisted valves with 3 angle seats (45.5mm inlets / 38.1 exhausts). Bronze valve guides. Fully ported. Head skimmed and combustion chambers CC’d to achieve 10.3:1 compression ratio. Head matched and dowelled to inlet manifold. Kent FR33 cam fitted with correct springs, rockers, longer ball studs and all geometry checked to achieve full lift figures. Ajusa competition head gasket (£40!) Kent alloy vernier. Ignition Modified distributor with fixed curve and vacuum removed, Lumenition ignition system, Micro Dynamics high output coil and Magnecor 8.5mm silicone leads. OMEX Clubman rev limiter. Fuelling Twin Weber 45 DCOE’s on MANGOLETSI alloy inlet manifold with K&N filters (note – the Webers were new when this went on the road 884 miles ago!). Facet Silver Top Competition fuel pump and alloy Malpassi Filter King adjustable fuel regulator. Cool air ducted from nosecone. Stainless 40 litre fuel tank with Alloy Aero style filler cap. Cooling Coolman twincore radiator. Alloy overflow / venting bottle fully plumbed in 12" electric fan and thermostat. Exhaust RH stainless 4 branch manifold into repackable silencer, thermal wrapped. Gearbox Sierra Type 9 5 speed box, all new seals fitted. Sierra 3.92 Diff, fully rebuilt with all new seals. Rose jointed quick shift gearlever Brakes New master cylinder. Front - New sierra callipers on new vented discs. Rear - Standard Sierra drums which have been overhauled with new shoes, wheel cylinders, springs and fitting kit. Drums skimmed. Stainless Steel flexible hoses front and rear. All new copper pipes everywhere. Suspension Bespoke front suspension – double wishbones with correct castor angle. All powder coated black. Gaz adjustable shockers. Rear suspension – AVO adjustable shockers. Electrics Premier Wiring loom. Sterling Cat 2 immobiliser. Battery cut off switch. Fuse box integrated into bulkhead - All fuses accessible from under the bonnet. Indicator repeater buzzers. Exterior Stainless body panels with wide arch option front and rear. All arches, bonnet, scuttle, nosecone and roll bar professionally painted gloss black. Fixed scuttle, bonnet and nosecone hinged from front of scuttle to allow lots of access. Lots of detailing and powder coating (front suspension, hub carriers, brackets, trimming plates, windscreen surround etc) New mini wiper motor, rack and wheelboxes. 7” WIPAC freeform halogen headlamps. Unmarked 15” Superlight alloys and as new Falken tyres. Interior Fully trimmed in black waterproof carpet and leather cloth. Sparco Sprint seats. Sabelt 4 point harnesses. Sparco ‘Ring’ steering wheel (Black Suede). Aluminium Sparco gearknob. Mini heater which demists windscreen and heats footwells (new matrix fitted). Individual CAi gauges. 12V Power point (which I use for trickle charger). Boot is covered in aluminium panels clad in leathercloth and is carpetted. Boot lid is lockable. I have all receipts for the kit and parts used, and it is correctly registered on the V5c as a Robin Hood 2B. 12 months MOT included. Any questions please ask, viewing is highly recommended to fully understand the detail that has gone into this build. £7200ono I'm located approx 10mins from the M1 J60 and can be contacted on 07805 513781. More photo's at http://s1126.photobucket.com/albums/l613/stobbart1/
  3. Facet Red Top fuel pump for sale - includes 90 degree unions. Used but in good working order. £30 delivered. You will need to purchase a couple of rubber bobbins to mount it. Send me a PM if your interested Cheers, Neil
  4. Two pairs of black Faulkener 1.9" diameter coil springs for sale - in fantastic condition. One pair 225lb 10" free length One pair 175lb 9" free length Bought from Demon Tweeks and currently retail at £25/spring + postage. Looking for £25/pair + postage.
  5. Brand new 2B hood, fixings and both hoops which have been powder coated black. The hood is still in the bag as new - never fitted to the car although press studs have been fitted to front rail. Doors not included. Looking for £175 plus postage. Now sold.
  6. Just renewed with Premium Choice yesterday - renewal quoted £146. Rang Pickles and found him really helpful - quoted £131 but couldn't do agreed value as he is struggling to get it agreed for most things at the moment (he quoted a case of struggling to get agreed value on a brand new caterham worth £38k - agreed value was set by insurer at £34k!) Rang Premium Choice back and got renewal down to £132 fully comp parts only cover for wife and I to drive (incl commuting) - £9k agreed value. Appears to be exactly the same policy (KGM) other than P/C can do agreed value. Andrew at Premium Choice was great to deal with and emailed cert within 20 mins.
  7. Just renewed with Premium Choice yesterday - renewal quoted £146. Rang Pickles and found him really helpful - quoted £131 but couldn't do agreed value as he is struggling to get it agreed for most things at the moment (he quoted a case of struggling to get agreed value on a brand new caterham worth £38k - agreed value was set by insurer at £34k!) Rang Premium Choice back and got renewal down to £132 fully comp parts only cover for wife and I to drive (incl commuting) - £9k agreed value. Appears to be exactly the same policy (KGM) other than P/C can do agreed value. Andrew at Premium Choice was great to deal with and emailed cert within 20 mins.
  8. Hi Steve, Ickle has sent payment. Thanks for your interest. Neil
  9. For Sale - Complete RH 2B Steering Rack as supplied by RHE in 2B kit - only used during build so as new. All gaitors, track rod ends etc included. Excellent condition. Looking for £30.00 & postage.
  10. For Sale - Standard GBS Stainless Steel silencer for 2B - only used during build. Good condition, not modified / repacked. Looking for £45.00 & postage.
  11. Can't recommend the Premier loom highly enough - I used it. Easy to follow instructions, loads of support via the phone should you need it. A quality piece of kit.
  12. Steve, How urgent do you need it? I'm about to change my drum braked rear axle for a disc braked set up so will have trailing arms, bearing carriers, drums etc with new hydraulic cylinders etc available early in March if you're interested. I'm in Bishop Auckland so we could sort something between Bishop and York. Neil
  13. Hi Andy, Congratulations and best wishes to both of you. Neil
  14. One of the guys at work has just had his golf GTI wheels refurbed by a place in Sunderland which included blasting, powdercoating then remachining the face and laqering. Looks a top job - back to OEM finish in fact. I'll get the details for you. Neil
