Everything posted by Foz
Dirty Duck 2 revisited
You're just trying to confuse an old man aren't you - well you succeeded 🤣 I've booked plot 25 from Friday to Sunday - as ever I'll do my best to be there ........... barring normal disasters 🤪 I haven't booked my pass out yet so I'll have to let you know about the meal later. Steve
GBS Zero Rescue
I'm impressed, it's looking very professional and if you carry on at this rate you'll be on the road by the weekend 🤣
Staffordshire Area Meet 26th June 2025
All being well I'll see you there - just because I drank your beer last month it doesn't mean you can drink mine this month 🤣
The Motorist Kit Cars & Modified - 9th August 2025
Hi Matt, Welcome to the club. Your area secretary is Andrew Wilkinson (Grim) and you can contact him via the "Staff" page on the blue section at the top of this page. You'll find a message button by his name. He should be the best person to answer your questions and will let you know of any area meets.
tiger cat E1
I'm not sure how the coil-overs are fitted on your car but can you fit a spacer under the bottom mount (or above the top) ?
Two Questions re: bonnet support and steering rack
Can you just fit foam filters as it is ? Have a look at Ramair filters for some idea of what is available. I fitted "universal" boots to my rack, just them cut down to correct size ends. I can't remember where they came from but it was probably from somebody on ebay 😜
- AGM 2025 Agenda
New Westfield Owner.
Have a look on the community map page to see members in your area. You could also have a word with Robbie 2B or ThanasisPolitis (you'll find them on the Staff page) they are the area secretaries for the South West and South East and you can message them directly from that page.
Staffordshire Area Meet 29th May 2025
All being well I'll be there - if only to drink Andi's beer 🤣
National Kit Car Show 2025
I should be there but I know from experience that if I say I'm definitely going to be there on Saturday the brown stuff will hit the wizzy thing and I won't make it 😜 So to avoid the risk of disasters I'm going to say ................. probably see you all on Saturday 😃
GBS Zero Rescue
Hi Jake, welcome to the club. It should make a cracking car when done, take your time and you'll get there. Stick your location up and you may well find there are other members local to you willing to help or advise. Good luck 😀
Raising Car an inch or 2
It's amazing what you can do if you've got a big enough hammer 😜 We had a quick measure up of the bottom chassis rails on Chris's car "empty" before we started and found that the back was about 10mm lower than the front and the driver's side was about 10mm lower than the passenger side. This lean was confirmed with a spirit level across the roll bar. There are tank trap sized speed bumps on the way to Chris's house so we knew the car had got to go up about an inch to stand any chance of getting over them. Removing the top mounts for the rear springs we re-drilled them to lift the passenger side 20mm (ish) and the driver's side about 30mm (ish). Somehow or other we managed to get this right fist time ! We then wound up the coil-overs at the front, lifting the driver's side by about 20mm and the passenger side a bit less. We then checked the weights on the front wheels and adjusted the passenger side to get it correct within a few kg. When we'd finished the driver's side was about 5mm high "empty" and 5mm low with Chris in the seat (near enough I reckon), the rear is now about 10mm higher than the front and the car has the typical 2B stance with a fist sized gap between the rear wheels and arches. The plan is to clock up a few miles in it now and see how it goes before deciding if anything else needs doing. Total cost was 3/5 of nothing much and a few hours of micky taking - it would have been a lot quicker if I hadn't wasted a good couple of hours trying to stop Chris humming the theme tune to Raiders of the Lost Ark 🤣 however, he was very good a fetching all the bits that I managed to keep dropping into the pit 😀
Parts missing
Getting a fuel pump and sender shouldn't be a problem - have a look at somewhere like Car Builder Solutions for some ideas on what's available. The 2B normally had a "4 into 1" or a "4 into 2" set of down pipes that bolted straight to the pinto head (there was no manifold as such). If you haven't got those pipes you might find someone on here has a set tucked away, alternatively you should be able to get a set made by a decent exhaust builder.
All being well I'll be there on the Saturday.
Just an update for anybody following this - The front coil-overs are adjustable, there is a rubber boot covering the nuts and hiding the adjustment. Rear is separate spring and damper (as Sierra) but top mount looks like it can be "adjusted". The plan is to get it over the pit in the next few days and see if we can lift it by about 1" front and rear which should solve the problem. It does have a shortened sump so no damage there (yet). Watch this space for success (or fail) report 😜
- Raising Car an inch or 2
OK, I'll send you a pm over the weekend (when I know what I'm doing next week) with my mobile No. and we can arrange something.
First question - is it just the front end that you want to raise ? Can you tell which part of the car is catching the ground ? OK, that's 2 questions 😜 It doesn't look like your front has adjustable coil-overs so the easiest option is probably a spacer block between the bottom of the damper and the bottom wishbone. How to raise the rear will depend on what you've got at the back .......... of your car ! I'm busy all this week but could probably nip over and have a look at you next week if that's any use ? Steve
Selling Robin Hood
John has not visited the forums since November last year so I'd say it's very unlikely he still has the car.
Staffordshire / Shropshire events May 2025
There's a few events coming up, fairly local to myself, that I know of if anyone is interested :- Thursday evening 8th May Car meet at Tern Hill Hall TF9 3PU https://ternhillhall.co.uk/events/ Sat & Sun 10 & 11th May Blythe Vintage Rally ST18 0LT https://www.facebook.com/theblythevintagerally/ Sunday 18th May Autoextravaganza at Heakley Hall Farm ST6 8PW https://autoextravaganza.co.uk/ I'm hoping to make it them, weather and wife permitting 🤪
Past members grandson racing at silverstone
I'd certainly be interested in that Phil - I might only be able to make the Sunday but hopefully could make both days.
Staffordshire area meet Thursday 24th April 2025
Great to meet you and the family last night. Your car looks good in the photo - looking forward to seeing you in it next meet 😃
Don't worry Andi - I'll drink your beer for you, it won't go to waste 😆
We normally meet on the last Thursday of the month and you're always welcome to join us, with or without your kit. We do try to make it in our kits but often "issues" or the weather mean we're in tintops. Steve
wishbone or frame?
That seems quite a bit out, even by RH standards - as I remember, a washer or two was needed on mine but I think you're going to need more than 2 there!
