alfaGTA
    1,062
alfaGTA last won the day on April 11 2017
alfaGTA had the most liked content!
298 Excellent
5 Followers
About alfaGTA
  • Rank
    Drug Dealer
  • Birthday 08/12/1982
    MK INDY (sold), Octavia VRS, MK1 mx5
    Keith
    Watnall, Nottinghamshire
  1. As suggested above, "surcharges" will be incorporated into the total price by all parties - it is after all a business expense. However, Handling fees have not yet been banned to my knowledge?
  2. alfaGTA
    Welcome Back!
    Back in the gang again.......... not many changes here! MK is long gone, made way for the garage conversion though MX5 still going strong, hasn't been to Scotland yet..... nor Wales for that matter. Hope to catch up with a few faces at Stoneleigh this year, might even dust off the tent and stay the night
  3. Dinnae worry Richard, the roads are not going anywhere! To everyone else, I haven't had a chance to peruse the maps yet but I will put forward some more awesome roads to surprise!! Think I've found one near Glencoe though Ties in with a lunch stop too
  4. I have two boxes for sale, both with bell housings, neither with gear sticks. One is fully working £200 ovno One had third gear burst by a v6 cossie (I believe it's just a 4 cylinder box not a v6 box) £100 ovno
  5. I have an unwanted gift that is brand new in the box.... Spec; 42mm case, 316 stainless steel, sapphire crystal Retina display, ceramic black, Milanese loop with magnetic closure. £500 May be interested in a similar value watch as a part ex
  6. alfaGTA
    Radiator
    I have a brand new vw polo radiator free to a good home (you pay postage) to rhocar members only though! Plenty of aluminium mk1/2 escort radiators about that will cool it adequately..... Mind to future proof your system in case a turbo gets added later
  7. alfaGTA
    Storage Boxes
    Those are tote boxes An eBay search reveals plenty stolen from the wholesalers that supply pharmacies..... Think they are ~£80 brand new!!
  8. alfaGTA
    Cooling System
    Renault clio mk2 or kangoo have a nice expansion bottle with a bulkhead mount
  9. alfaGTA
    Cooling System
    GBS kit will cost £217.98 for the thermostat housing and rail but it only gets water to the front of the engine, you still need £81.71 to connect the radiator to the water rail and the water pump to the radiator. Plenty of options out there for an inline solution http://www.carbuildersolutions.com/uk/aluminium-modular-inline-housing-32mm http://www.carbuildersolutions.com/uk/aluminium-modular-insert-14-npt-female-thread The ford pinto water temp sender I linked earlier is 1/4npt fitting (Rob/CMA used it too) It doesn't have to be complex
  10. alfaGTA
    Cooling System
    The retroford item is £206 and only gets the water from the back of the engine to the front.... You still have to connect it to the radiator and from radiator to water pump. AutoSiliconeHoses are perfectly up to the job. IF you could find a person with a mandrel pipe bender you could create a very neat curve in the aluminium TV mast that would reduce the number of joins and reduce the potential for leaks.
  11. Fast forward to 5:30.... I thought the wildlife was dangerous enough never mind the humans!
  12. My garage is being converted to light industrial storage and distribution for my proposed internet pharmacy business, head space is limited (I want the storage space) so a sectional door is not suitable. DanE i'll be in touch, I forgot yours was roller!
  13. alfaGTA
    Cooling System
    Here is some costing research material...... End caps to block the heater outlets on the standard ford thermostat housing (think its 22mm) http://www.autosiliconehoses.com/silicone-hose-end-caps-2-pack-blanking-plug-bung-4mm-to-32mm.html One 90 degree angle to aim the water from thermostat to the front of the car (think its 35mm to 32mm) http://www.autosiliconehoses.com/silicone-polyester-reinforced-hose-90-degree-elbow-reducer-35mm-to-32mm-15-colours.html One TV aerial mast from B&Q (32mm outer diameter and aluminium) to carry the water from the 90 bend to the radiator http://www.diy.com/departments/tristar-silver-outdoor-aerial-mast/571738_BQ.prd One top hose thermostat kit to switch on and off your radiator fan (first one I found on ebay) http://www.ebay.co.uk/itm/35mm-RADIATOR-TOP-HOSE-THERMOSTAT-KIT-FOR-ELECTRIC-FANS-/141736372405 One water temperature sender to feed info to your dash and ECU (if you are lucky it will screw into your ford thermostat housing though you may need to source one of those, it will also need earthed to the block or head) http://www.burtonpower.com/temperature-sender-early-sohc-ford-pinto-x-flow-essex-xtt14.html Probably want 2m of silicone pipe to be safe http://www.autosiliconehoses.com/silicone-polyester-reinforced-hose-32mm-choose-from-15-colours.html You will need a 90 or 120 or 135 degree bend for the water pump too (think its 44mm on the water pump reducing to 32mm) http://www.autosiliconehoses.com/silicone-polyester-reinforced-hose-90-degree-elbow-reducer-42mm-to-32mm-3-colours.html Jubilee clips to join it all together (i prefer Mikalor brand but screwfix are ok) http://www.screwfix.com/p/stainless-steel-worm-drive-hose-clips-20-50mm-pack-of-10/69166 You will also need an expansion tank and some 8-10mm silicone pipe work to plumb it in. As per Rob (CMA) above mine was a home brew affair, my only weakness was a poorly sealing expansion bottle!
  14. Does anyone here fit or supply such things? Prefer remote electric, white, 8'x7' and quiet! Currently I have an up and over hormann in good condition but i need something draught and rodent proof (also to keep burglar bill out).
  15. Only need three days hire really, passenger ride to Glasgow airport, whore around for three days then drop back to Edinburgh airport and bag a lift back to Notts.... £762.75 for the three days. Boxster is cheaper at £534. I'm not 100% serious but it does give a viable option especially with the Boxster.
